Holo Audio Red Streamer
Dec 13, 2022 at 7:13 PM Post #211 of 1,916
RED eagle has landed!
Testing just few minutes though. There is no user manual in package and no user manual online yet. Going to test as DDC right now. Too soon to comment on sound quality, will do after 1-2 weeks of burn in.
Just small hint. Already better than Matrix X-Spdif 3 via AES/EBU. Going to test I2S next.
Stay tuned.
Can't wait to hear your impressions:L3000:
Dec 14, 2022 at 5:12 PM Post #214 of 1,916
Would a Red be an upgrade over a Raspberry Pi 4 (with Shanti LPS) using USB out to an Holo May? Mostly using HQPlayer through Roon.
What are you running HQP on if you don't mind me asking?
Dec 14, 2022 at 7:42 PM Post #216 of 1,916
I would like to know the same. In my case, I'd be running HQPlayer Embedded on the Red itself as I only need PCM 4x upsampling which a Pi Compute 4 should be able to handle.
Dec 14, 2022 at 8:10 PM Post #217 of 1,916
Just checked and DSD1024 works fine via HQP on RED OS. So yep, PCM1.536mhz and DSD1024 work fine
Dec 15, 2022 at 7:34 AM Post #218 of 1,916
Any insight on this: Would a Red be an upgrade over a Raspberry Pi 4 (with Shanti LPS) using USB out to an Holo May? Mostly using HQPlayer through Roon.
You seem to have tested a lot of stuff so I value your opinion. I don't doubt the Red is better in every way than a normal Pi but the USB port on the May seems to do magic.
Dec 15, 2022 at 10:12 AM Post #220 of 1,916
On a Holo May no.
USB sources have no effect on the May due to the full isolation it has. On other DACs possibly yeah
Dec 15, 2022 at 11:09 AM Post #221 of 1,916
Hi, any new impressions?
Not yet. I am not at home right now. I've just let unit plugged in to my streamer (music on repeat 24/7) to burn in. Will test again during weekend.
Dec 15, 2022 at 1:22 PM Post #223 of 1,916
What is it going to replace in the chain in your signature? Or is it going in another system?
