What's the rest of your gear in your setup?Everybody already bought one
Hysteria or not, I’m happy with mine. I was afraid that I might regret of selling my HMS-DAVE after impressions of a “new toy mode” calm down, but that didn’t happened. I only like May more and more.
Holo Audio May DAC Speculation
- Thread starter oneguy
- Tags
- holo audio may dac
Ragnar-BY
Cyrus CDt-XR (CDs) and opticalRendu (roon) as sources, Riviera AIC-10 amp and T+A Solitaire P headphones.What's the rest of your gear in your setup?
ThanatosVI
Quality stuffCyrus CDt-XR (CDs) and opticalRendu (roon) as sources, Riviera AIC-10 amp and T+A Solitaire P headphones.
Ragnar-BY
By the way, if anybody is thinking about new CD-spinner for his May - try latest PS Audio transport. It sounds outstanding via I2S.
The only downside is a price and limited availability in Europe.
Palyodgree
The new PS Audio transport looks interesting, it looks like resurgence of the cd transport ,,…I had a outstanding transport to try from Austria , a Project RS2 with upgraded power supply. playback was absolutely spectacular and with select CDs , it rivalled anything I’ve listened to so far however it would be difficult adjusting to the switch away from the ultra convenience of managing ones music library.By the way, if anybody is thinking about new CD-spinner for his May - try latest PS Audio transport. It sounds outstanding via I2S.
amatihomage
Does anyone know why Holo May is shipped with a firmware that only supports pcm 768 Mhz and DSD 512 when it is marketed with support for pcm 1536 MHZ and DSD 1024?
Ragnar-BY
Does it work with May via i2s?I had a outstanding transport to try from Austria , a Project RS2
Palyodgree
Unfortunately not , chatting with the owner he tells me the I2s pin out of the this transport was chosen only for the Project product line however never the less SDIF coax connection performs on a very high level .Does it work with May via i2s?
branislav
- Aug 11, 2011
I see Holo May KTE went up $600.
amsync
Well mine got delivered not too long ago and I could stream 1536 out of the box on usb via hqplayerDoes anyone know why Holo May is shipped with a firmware that only supports pcm 768 Mhz and DSD 512 when it is marketed with support for pcm 1536 MHZ and DSD 1024?
amsync
I use this one with an LPS and its fantastic: https://www.pinkfaun.com/shop/bridge/69-4374-i2s-bridge.html#/194-bracket_height-120_mm_74_inchNow the only thing I want is a good Roon endpoint with i2s out and support for DXD and DSD256.
ThanatosVI
Bummer, the "street price" of the Wavelight also went up.I see Holo May KTE went up $600.
rcoleman1
Sucks but it's still on my radar.I see Holo May KTE went up $600.
Ragnar-BY
Unfortunately Pink Faun is limited to 192kHz, PCM-only and requires to build a computer to use itI use this one with an LPS and its fantastic: https://www.pinkfaun.com/shop/bridge/69-4374-i2s-bridge.html#/194-bracket_height-120_mm_74_inch
amatihomage
Strange! could it be that I have an older model?Well mine got delivered not too long ago and I could stream 1536 out of the box on usb via hqplayer
My serial number 2107376185-
Last number removed
