Non KTE internals
The one thing I know about this amp, other than the power and size of it, is that it was 100% made using the Susvara. It’s supposed to be a perfect pairing for it and I’m sure any other headphone you’d throw at it as wellI spy twin xlr and RCA inputs as well as one XLR output. Preamp?
Also, 12 watts into 32, so does this mean 6.5 into 60 aka Susvara?
Perhaps XLR and RCA output and two XLR + one RCA input?I spy twin xlr and RCA inputs as well as one XLR output. Preamp?
This is what Tim said (bold are my own):I hope it has a preamp in it. I wanted to buy Serene (especially now for Enleum Amp 23R and May combo) but I usually have other things to spend money at. I was thinking about buying Ferrum stack but then I realized that Bliss is around the corner and it’ll be probably around this price range. If it has a preamp then it would be perfect.
Then again there is a Serene so it can be troublesome if they are similarly priced. Or maybe Serene will be withdrawn?
The bliss will also be a preamp bit not nearly as good as the serene is at being a preamp.
There are compromises either way. Bliss will be focused being a headphone amp. And serene is focused at being the best preamp, just happens it’s (serene) also a decent headamp but wont be at the level of the bliss.
