I got my HoloAudio setup a couple of days ago. the sound chain is: Roon | DMP-A6 | HoloAudio Spring | HoloAudio Bliss | Headphones
I am not finding much of a difference between the LO-Z and HI-Z output levels on either of my headphones. I am using the Stellia and the Expanse.
If at all LO-Z is marginally louder and I'd say it's about 5% at most.
Is this normal as I was expecting something akin to the level's suggested in the manual.
I am connected using the Lavri Grand XLR cables to both headphones.
so I am doing the burn in and woke up this morning to find the bliss fairly warm. warm enough to be uncomfortable to put my hand underneath both it and above the Spring which are about 1.5" apart
So.. if i am not mistaken i think it is not reccomended (check the user manual) to put bliss on top of spring, and yes bliss gets hot on the underside.
Bliss is recommended to go above (pic below). They suggest leaving 2" between them and I am using an IsoAcoustics spacer which is giving me 1.4" of room. I could extend it by using the feet of the Bliss but that would be less stable (has anyone tried this as a solution?).
I am also not covering any of the vent holes. The screenshot from the manual suggests a attached heat map, does anyone have a copy they can share.
