More than lucky!, When I decided to buy, I entered on Sunday to Magnahifi and was out of stock, I kept looking things on the page, and then I backed to the Bliss page 15 min later and was in stock.
I have funny stories like this. I remember on pandemic, with the release of NVIDIA 30 series, the people was complaining because 2h after the release, the page still says no stock, and when I enter, I saw the button and bought as well payment process so fast. And people that were there spamming F5 could not buy. Apparently all the stock was put 2h later and remained less than 2 mins available. Also with the release of Ryzen zen 3 processor. You know how difficult was by that time to get decent hardware.
So ... the Bliss requires substantial burn in?? Am I nuts for loving this device right out of the box? VERY impressed with how it sounds. I love my Ferrum OOR but this sounds like a considerable step up. Awesome. How much better does it get with burn in, I wonder... We will see. Happy camper right here.
Has anyone tried Susvara with 1/4 inch cable on the Bliss? Wondering if I should get another balanced cable. The one I do have is at work for my other Hifiman right now. And... I do not want to use the one it comes with haha.
I just changed from the XLR port to the 1/4 inch, using a pigtail adapter. With XLR I was listening at -9. Changing over to 1/4 inch, I need to turn it up to -1 or so to get to the same volume level. It tops out at +12. This would be at ~80 dB, a little louder than I usually listen (due to excitement... ) Notice that the Bliss is being fed by the DAVE, which puts out 6V I believe, so quite a lot for a DAC.
Difficult to describe accurately. One element is more weight in the (sub) bass. Staging is another. Overall it just sounds... better. So smooth and effortless. The OOR (yes with Hypsos) is great, but this is next level for me. Please bear in mind the honeymoon effect, lack of proper burn in etc. etc.
I have the same DAC and keep the volume set at 95 when feeding the Bliss. Works great.
After some experimenting my preferred setup with my tube amp (Cayin HA 300 MKII) is to use the Bliss as a preamp into the Cayin. In this configuration setting the Bliss line out volume to -10 works great too. Sounds great and no blown fuses so far (knock on wood 3 times ).
Now you are talking about voltage outputs, how about a Spring 3 no pre amp module in these scenarios?:
1) feeding Bliss directly via XLR
2) feeding Euforia AE as pre amp > Bliss (or vice versa)
Now I read @mfgillia talking about blown fuses I get paranoid. Do I need to use atenuators in case 1 as I dont have control of db's before Bliss? what about case 2? Would be heartbreaking to fry my new babies.
This exact combination of amps worked perfectly for me without issue. My Spring 3 has preamp, but I ran it at 94 which has voltage output equal to no preamp version.
That was a perfectly comprehensive review. The only thing that might have been clearer is sonic differences between the headphone sections of the Serene KTE and Bliss KTE running more normally efficient headphones. In regards to the Bliss KTE and Serene KTE, I’m trying to chose, which performance compromise to make, a potentially better headphone section in the Bliss KTE or a better preamp section from a Serene KTE. I only use low impedance 97 db efficient headphones like my HiFiMan HE 1000se and Grado RS1x and a ratio of 50/50, headphones to 2 channel speaker system listening. I will never run an inefficient phone like a Susvara. How would the Bliss KTE vs Serene KTE headphone sections compare running only efficient phones such as these?
Providing I could achieve the same level of headphone performance on a high-efficiency, low impedance phones, and gain a better preamp with the Serene, wouldn’t that be the better choice with less sonic compromises given my system requirements? Using the Serene KTE as both a headphone amplifier and preamp I might be giving nothing up, but with the Bliss KTE, I might be compromising my preamp performance. Any thoughts would be appreciated.
I've been thinking about running the 300 MKII using the Bliss as a preamp. Right now, I've got it running out of the Spring 3 with RCA and I am totally enamored. It's really nice having the variety between the two units.
