SlothRock
I mean here's a short video of the settings menu if anyone finds anything else:
A lot more simple and intuitive than I was anticipating which I’m a big fan of! Can’t stand menu scrolling. Good stuff
Holo is a Toggle, not both outputs at same time. Now historically RCA and XLR preouts are both active at the same time though.Do the preamp and HP out get signal at the same time? Or can they be set individually? Usually try to stay away from HP amps that cant toggle between outputs, but Holo is probably the only time I'd make an exception.
Do we know what the wattage or volts difference is between the two impedance switches? I am assuming the switchover is around 100 ohms. So, everything planar and low-impedance dynamic (utopia, stellia, etc.) is Low-Z and else is high-Z like ZMF, Senn, Beyer, etc.Watch the video that was posted above - you have to select the "Line out" (preamp) or HP out w/ Low Z or High Z as the output options. I also like the fact that you have to toggle between the two. I feel like my OOR gets extra hot because all outputs are running at once.
Agree with this 100% - it was actually one of the reasons why I got rid of my Burson GT for the Ferrum OOR+Hypsos. Volume adjustment wasn't good enough, even with low gain and the volume at 1 in some cases. Hoping Bliss solves this and the volume control is perfectAlso something that I'm interested in: When used in May -> Bliss -> Utopia, can one get the volume low enough? With SparkoS Aries my only complaint has been that even the lowest volume setting is quite loud in this chain. I'm using HQPlayer so it's not a complete deal killer, but digital volume control just doesn't feel the right way at this level.
I think if there is a 4.4mm output to support IEMs, my guess is that you would use this for super-sensitive headphones. Or, at least, the thought is in the design itself.Agree with this 100% - it was actually one of the reasons why I got rid of my Burson GT for the Ferrum OOR+Hypsos. Volume adjustment wasn't good enough, even with low gain and the volume at 1 in some cases. Hoping Bliss solves this and the volume control is perfect
Not to mention IEMs that actually like "real" headphone amps, like UM MEST Indigo.I think if there is a 4.4mm output to support IEMs, my guess is that you would use this for super-sensitive headphones. Or, at least, the thought is in the design itself.
The comparison with Pass HPA1 interests me most. I already own a TOTL OTL HPA and am looking for a suitable SS to add to the stable.Comparison wishes: SparkoS Aries, Niimbus, Pass HPA-1.
