bcwang
- Feb 28, 2003
I haven't used my two shure IEMs in a while, but in the past I remember the SE530 sounding much better than the E4. However, recently I began trying them out again, and after noticing my E4 was clogged (sound softer on one side), I replaced the nozzles and got comply eartips. Then I listened to the two headphones....
Hmm, why does the E4 sound better than the SE530? It actually seems to have more bass than the se530 which is not what I remember. It also seems so much more clear, while the SE530 seems very laid back and lacking detail. The SE530 are using shure olives too, trying the comply made them much worse losing even more detail. Maybe the nozzles are clogged just like the E4. They don't have replaceable nozzles though so I start cleaning it to see nothing coming off. Well a more aggressive attempt later I punched through the paper filter. Great, now one side is louder than the other. So I am forced to punch through the other one as well to balance it out. Well, I'm not sure if the sound changed as I can't go back and compare anymore. But what is still clear to me is the E4 still sounds better.
So do you guys think my se530 is busted if it's being beaten by the E4? I think the E4 fits me much better, especially with the comply tips. The isolation is much better. But nothing I can do can get the se530 to isolate the way the e4 does, I think the body might simply be too big to fit deep enough into my ear. So maybe it's the fit that is causing the difference.
But in any case, I'm liking the E4 a lot right now, the nice deep fit and great isolation which I don't get with any of my other IEMs, coupled with the clear sound. I'm going to have to give the SE530 another chance later but right now it's beaten.
