tupac0306
- May 11, 2011
Thanks man! so how to proper untag the art? I can only do it through itunes. any link?
MP3TAG works fine?
MP3TAG works fine?
MP3TAG works fine?
Here you go. Follow these directions and it should work. You may want to make an extra copy of the files you intend to put on your Studio V just in case you make a mistake so you can easily go back to the drawing board .
Step 1: Download Mp3tag
Step 2: Go into Tool/Options. Under Tags you have Mpeg and Ape, Mpc... You want to make sure Read is check marked for both Mpeg and Ape. For "Write" make sure only ID3v1 is checked (for both Mpeg and Ape). Under "Remove" check ID3v2 and APE. If you have APE files it is recommended not to use them as those files work slow on the Studio V. Convert them over to FLAC instead. Then select Ok to apply changes in options.
Step 3: Drag and drop your files you wish to apply this to. I recommend doing this from your Hard drive if you wanna save time as the changes can be applied much faster this way. Then again reloading your Studio V and SD card could take the same amount of time. It's really only a 1 time process thing so it's not a big deal. Anyways once you've dragged and dropped the files you wish to apply these changes to, highlight all the files or click on the "Filename" area and then press Ctrl + A. Now Select Remove tags or that big X just below "Edit" (top left corner area of Mp3tag). Once all tags have been removed simply click "undo Changes" located next to "Remove tags". This will restore all your tags on the fly except for v3.2 tags. To be on the safe side you can also select "Save" to ensure these changes stay. This is located to the left of "Remove tags".
Step 4: I also recommend cleaning up your tags. If you have junk such as "Comment", "Composer", "Disc number", and "embedded album art" this will all contribute to slowing down your device. I'll tell you how to remove all this on the fly. Again press Ctrl + A to hilight all your files. Then under Comment/Composer/Disc number select <blank> for them all. Once you've completed this now right click on the album art area (located below disc number). Select "Remove Cover". Now all you have to do now is Select "Save" and it will apply all these changes for you (just make sure all your files are constantly hilighted when doing all the above directions in order to apply them).
Problem should be solved and your player should be rather responsive on start up. Mine takes roughly 16 seconds (correction) to load from the SD card and on-board. I did a countdown myself and it's 16 seconds for my unit (20 seconds if you start the countdown from when you first power the unit on). Enjoy folks!
Studio has the power needed for full size headphones, unless of course, massive voltage is necessary for some headphones. Works great with my 600Ω DT880, but that is an easy-to-drive headphone. Haven't heard it with the K701 yet, but it seems fine with the HD600.
If it can power the HD600 or 650 then it must be good...
