BoxBoxBox
Aka: AndrewG
- Nov 6, 2005
What is the highest capacity player, with flash capability and can play rockbox or FLAC?
Originally Posted by rawrster /img/forum/go_quote.gif ^ that's not a flash hd? ![]() cowon d2 goes to 32gb (16gb internal +16gb sdhc). i'm not sure how rockbox goes on that since under the rockbox site it says unstable port but some people use it so you should probably search or check iaudiophile.net. if you dont want touchscreen 8gb fuze+16gb microsdhc. also i believe the nationite s:flo2 does 16gb and i think 16gb microsdhc is supported (not sure since i dont own one or keep up with it) |
Originally Posted by Young Spade /img/forum/go_quote.gif ^This. If you don't mind the mild buggieness that people say it has and the low battery life (around 8 hours with FLAC), it's an amazing player. PLUS a dedicated line out port ![]() |
Originally Posted by rawrster /img/forum/go_quote.gif cowon d2 goes to 32gb (16gb internal +16gb sdhc). |
Rockbox is not developed for the sflo.
