AudioDoctor
Cool. Add a speaker connectors (usually bananas it seems but spades are fine too) to 4pin XLR, and you are good to go.
Amazed at how simple that is...
Never heard of this amp but with a super-resolving headphone like Susvara I would possibly look for something that measures better objectively.What do you guys think of this new amp? I don't think the brand is very popular and there's not a whole lot of reviews online about them. There's one review in Amazon from a dude in the US that says that these are more than enough to drive his HE-6SE even on low gain. Have you guys experienced gambling on similar amps with good results? Or is it way too much of a risk?
https://www.amazon.com/MUZISHARE-sinle-Ended-Integrated-Amplifier-Headphone/dp/B086QFMTQG
https://quartzacoustic.com/shop/muz...alanced-headphone-output-integrated-tube-amp/
Muzishare X3T EL84 Double Rectifier Class A Speaker and Balanced Headphone Output Integrated Tube Amp
Specifications:
• Output: 5W per channel
• SE Headphone Output: 900mW + 900mW (32Ω)
• Balanced Headphone Output: 1500mW + 1500mW (32Ω)
• THD: 0.5% (1kHz) • Frequency Response: 10Hz – 50kHz (-1.5dB)
• SNR: 90dB • Input sensitivity: 300mV¬ • Input Impedance: 100kΩ
• Output Impedance: 4Ω-8Ω • Tube configuration: 12AX7*2, 5AR4*2, EL84*2
• Voltage: 115V/220VAC 50Hz
• Dimensions: (W) 270mm * (D) 245mm * (H) 145mm • Weight: 8.4kg (gross)
The thing is that there are a lot of different personal experiences out there from devices that are technically the same but one costs more than the other.Well there is our personal experiences that we have shared but that’s (to use your technical term) just “blabla”
A question regarding a cable to connect the susvara to the pass amp. Is it possible for a cable to go from the speaker taps straight to the headphone, or is there some reason I am not aware of that I should use an adapter?
Still in search for the ultimate Susvara amp?https://fluxlab-acoustics.com/product/volot-dual-mono-class-a-headphone-amplifier/
Well, here is another contender..
Quite affordable as wellhttps://fluxlab-acoustics.com/product/volot-dual-mono-class-a-headphone-amplifier/
maybe in a few years we can arrange for an international susvara meet for all of us and our gear - that would be massive and maybe a 3 day eventNah.. I think I'm done. Still hoping to one day get to hear the amp13r.
Just sharing this one, in case anyone else is still looking.
Do/did you own the Wavelight and May at the same time?Personally I sold the Bakoon in favor of WA33. I've felt done with WA33 too but I've read a couple mentions of Tim @ Kitsune working on a Susvara amp called Holo Bliss. Not sure on release ETA, probably later this year. Would be tempted to try it since I like their May DAC a lot.
