HiFiMan Susvara
May 18, 2025 at 2:39 PM Post #28,756 of 28,803
My xlr stock cable is starting to fail in the right 3,5 end.
Does anyone have tried to fix it with a welding?
And, if I have to buy another, worth to go with something like forza noir hpc?
Is anyone selling an original one in EU?
I would buy a second hand cateter one.
You might be disappointed with the results coming from stock. Better get the same cable IMHO or you'll have to roll tubes to get the vividness of the sound from the stock cable back
May 18, 2025 at 2:48 PM Post #28,757 of 28,803
Contact hifiman customer service, they are usually pretty easy to work with, even after warranty expires/not first owner.
If they don't warranty it, fixing it is worth a try. A lot of people/reviewer has been criticizing their cables but I think they are not bad, they are hybrid silver/cooper design.
May 18, 2025 at 3:25 PM Post #28,759 of 28,803
May 21, 2025 at 6:19 AM Post #28,761 of 28,803
Just wanted to share this, my Susvara stack which to my ears sounds great. Fast and powerful controlled low, lots of detail without being sharp, separation… I love this setup.
Susvara stack;
- Source Bluesound Streamer Node Nano (N132) > USB out
- Source CD transport Shanling CR60 > optical SPDIF out
- DAC/preamp Naim DAC-V1
- Power amp NAP100
- Hifiman HE-adapter for ease of mind instead of direct speakertaps, don’t notice much difference
- King Susvara ;)
May 23, 2025 at 3:14 AM Post #28,762 of 28,803
Is the Buson Funk Max Current enough for the Sus with 3wpc?
May 23, 2025 at 6:36 AM Post #28,764 of 28,803
May 23, 2025 at 6:43 AM Post #28,765 of 28,803
So, the Funk is not enough juice?
My Susvara runs amazing off my 1.8W@60 Ohm HPA4. It's not about quantity of power but quality, as the past 1918 pages of this thread have discussed.
I would personally aim for roughly 3W+ just to be sure, so you should be solid with the Funk on a pure volume level. Whether distortion levels will remain okay I don't know, haven't heard it and haven't seen any measurements either.
May 23, 2025 at 6:56 AM Post #28,766 of 28,803
the funk could be outputting less than one watt from its headphone jack into the susvara's 60 ohm load, which may be insufficient to drive it adequately. and then there's the susvara's low sensitivity of 83db, which doesn't help matters.
May 23, 2025 at 7:10 AM Post #28,767 of 28,803
Where do you got this info from or calculated? The Funk Max Current has 3wpc@32ohms i think. this shouldbe 1.6w into 60 ohms.
V = √(P * R) = √(3 W * 32 ohms) = √96 = 9.8 volts (approximately).
P = V²/R = (9.8 V)² / 60 ohms = 1.6 W (approximately).
May 23, 2025 at 7:25 AM Post #28,768 of 28,803
Where do you got this info from or calculated? The Funk Max Current has 3wpc.
it's just a rough calculation based on burson audio's specs for the funk. according to burson audio, the funk outputs 3.5w from the headphone jack into a 16 ohm load and it outputs 2.5w into a 32 ohm load - so it will output fewer watts/less power into the susvara's 60 ohm load.
May 23, 2025 at 11:56 AM Post #28,769 of 28,803
My topping is 4w and it cant drive my susvaras to a loud listening. I get clipping.
I respect every opinion but my honest advice is to go with at least 8w at 16ohms for a SS amp.
The funk should not be a good choice for susvaras.
The soloist 3x is the cheapest burson amp which can drive the susvaras almost effortless.
I mean the topping is not unlistenable but you get A LOT less than susvaras can give. It is wasting too much the susvaras.
I only can talk about my experience, at 60ohms, topping a90 is less than 2w, burson gt, less than 6w and cayin soul 170ha, 14W. There is a big jump in soundstage, dynamics, bass quantity an even resolution between them.
Also tubes play best with susvara IMO.
Of course, not everything is power.
May 24, 2025 at 1:00 AM Post #28,770 of 28,803
It's not the power of the amp. I use a phonitor one at max volume and it's loud enough and doesn't clip and it's only like 300mw.
  • mb3
