yea, custom builds require some serious patience......... errrg...he is also very easy to work with,although the build took forever lol
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
So like do you not read any further back in the forum than the first page?So whats up with Susvara. Is it still the best. Is it still V1 or more versions?
DAC/AMP should make the big difference I have heard....watt is not watt.
...it depends on the quality
Potentially still the best. No big revisions other than 2.5mm to 3.5mm. Some people say there is a change, some don’t. Amp selection is crucial for this headphone according to many. Still amazing.So whats up with Susvara. Is it still the best. Is it still V1 or more versions?
Sorry, EFRF ?????
oh oh. Here comes that wave again……..DAC/AMP should make the big difference I have heard....watt is not watt.
What's the best setup u heard with Susvara at CanJam?On the way back home from CanJam London and, having listened to pretty much every single planar flagship outside of the T+A Solitaire P off the multiple high end sources each, I maintain the Susvara is still the benchmark.
I am somewhat biased towards the EF1000 but I thought the Feliks Audio Envy was an excellent amplifier too:What's the best setup u heard with Susvara at CanJam?
Have you tried the Auris Nirvana?I am somewhat biased towards the EF1000 but I thought the Feliks Audio Envy was an excellent amplifier too:
I had paired both of these with the DCS Lina DAC and master clock as well, and played around with the crossfeed options. The clock isn't worth the money but the DAC is very interesting and pairs well with tubes.
I did, yes. It was available on another booth and I took over the same Susvara unit. The Nirvana punched above its weight tbh, if you are interested in it then you would be pleased. But it does make the Susvara slightly warmer compared to the other two that are not as tube-y. To give you a better idea, I'd say the Nirvana is a mini Cayin HA-300MK2 that was alongside and is basically what you think a tube amp should sound like. Personally I'd rather use the Nirvana and the HA-300MK2 with dynamic headphones.Have you tried the Auris Nirvana?
I’m curious how it compares to the Feliks Envy..
Thanks!I did, yes. It was available on another booth and I took over the same Susvara unit. The Nirvana punched above its weight tbh, if you are interested in it then you would be pleased. But it does make the Susvara slightly warmer compared to the other two that are not as tube-y. To give you a better idea, I'd say the Nirvana is a mini Cayin HA-300MK2 that was alongside and is basically what you think a tube amp should sound like. Personally I'd rather use the Nirvana and the HA-300MK2 with dynamic headphones.
How would you describe them in comparison to the Nirvana (if u had a chance to head them both)? ThanksI would not call the Envy lean even with basic EH 300B
