Any thoughts on restocking on Adorama? December is around the corner...
HifiMan HE6 V2 Adorama
- Thread starter Kevintj604
bagwell359
Yup - thar she blows....
Are you referring to the outside grills?
bagwell359
Line up the tabs of the ring with the tab notches on the back of the can, lightly squeeze the pads, push in, let side squeeze go as you keep the pad against the back of the can. turn the pad so that the tabs end up about half way between the tab notches in the back of the can . Done if all tabs holding, if one or two not, rotate back to the tabs matching the tab notches, try to jiggle them in , and rotate and check again.Thats me (who sold you them). The rings will work just fine, I've never had an issue with them. The only thing is if you haven't done much pad swapping before, there is a knack to it with hifimans and it takes some practice to do quickly. Keep at if you don't manage the first couple tries, its doable. Eventually you will get to the point its like second nature and done in 30 seconds.
Oops sometimes the edge of the leather gets in the way, if so, trim a bit back, but too much and the leather won't hold and you'll have to glue it down, I know from experience.
bagwell359
FB seldom fails to follow profits. A little bit of pent up demand now, they should release the v3 with less glue holding it together (thought to be one of the reasons the v1 and v2 don't have that staggering bass impact of the 6 screw), with better cables, pads, rear screens and go with the gold not aluminum innards and market it as the long lost OG HE-6 redux with reviews and graphs to prove the bass impact is back. Heck they could even call it the "6 screw". Start them out at $799 and slip $100 every 3 months until they get to $399 and I guarantee thousands sold, and a drop of the resale of the OG's.Any thoughts on restocking on Adorama? December is around the corner...
They could seek out the originator of the "Code Sex" mod @LFF pay him a fee, and have an upmarket version for $200 more
Shane D
Tried this week with Ether angled pads. Not very impressed.
I put the stock pads back on today and they are much more clear and the sound is bigger, to me. The Ether pads do block out some sound that the more open, stock pads let through.
Worth trying, but I will be selling the Ethers on.
theangelboy
This has been my general experience with solid leather pads on this headphone, too. Generally, I've found they put too much emphasis around lower midrange making everything sound "thick," for lack of a better term, and not really in a good way. I am of the camp that this headphone needs pads that breathe to sounds it's best. The stock PaliPad is about halfway between a solid pad and something like a velour (which is my fave).Tried this week with Ether angled pads. Not very impressed.
But now you have tried it, you know they aren't for you, and that's always helpful to be able to put that nagging "what if" out of your mind. At least, that's been my experience and why I tried so many pads on mine (over 2 dozen). I don't want to worry about be leaving some magical combination (for my ears) on the table (like the sheepskin Ori on the HE-400). Everything I try just reaffirms that my ears like velour pads the best on the 6se.
Anyway, sorry for the ramble. But thanks for sharing your thoughts on them. Happy listening!
![O2 Smile :o2smile: :o2smile:](https://cdn.head-fi.org/e/headfi/o2smile.gif)
Shane D
I had always wanted to try them, but buying the pads and clips from separate companies would have put me out close on $200.00 in Canuck bucks, landed. I got these for much less and I won't lose a whole lot on resale. Cheap way to try them out.This has been my general experience with solid leather pads on this headphone, too. Generally, I've found they put too much emphasis around lower midrange making everything sound "thick," for lack of a better term, and not really in a good way. I am of the camp that this headphone needs pads that breathe to sounds it's best. The stock PaliPad is about halfway between a solid pad and something like a velour (which is my fave).
Anyway, sorry for the ramble. But thanks for sharing your thoughts on them. Happy listening!![]()
What velours are you using? Are you referring to the HiFiman Velour pads?
I think I would probably enjoy a leather pad that had a nice wide opening like the stock pads. But I am not going to spend $200.00 or more to find out.
theangelboy
Yeah, stuff gets pricey in Canada Land! I can totally understand not wanting to drop that kind of dough. I haven't tried the Ether pads specifically since I don't feel any pad is worth the ~$100 USD it would cost me, stateside. I got burned a long time ago buying pricey pads that everyone swore were awesome and I hated the sound of them. So, I typically won't drop over $50 on a pad without a really good reason. I have tried several genuine lambskin pads on the 6se and all had some similar traits (that I don't care for) so I really haven't pursued the Ether ones.I had always wanted to try them, but buying the pads and clips from separate companies would have put me out close on $200.00 in Canuck bucks, landed. I got these for much less and I won't lose a whole lot on resale. Cheap way to try them out.
I think I would probably enjoy a leather pad that had a nice wide opening like the stock pads. But I am not going to spend $200.00 or more to find out.![]()
But, speaking of sheepskin pads with larger openings, I picked up a pair of sheepskin TH900 pads on 11.11 AliExpress sale for peanuts after all the coupons and such. Those have a pretty big ear opening and I plan to try them on my 6se (like I do with every pad I get that will fit it, lol) so I will let you know how that goes, if you are curious. I will probably recieve them in the next week or so.
The velours I currently have on my 6se aren't the official Hifiman ones, they are some generic ones from AliExpress ("Khopesh" was the store name) that sound and measure almost the exact same as the official Hifiman ones. The reason I use them over them over real ones are that they are softer and more comfortable. They were only like $4 and were great so I bought a bunch of sizes of them for various headphones that I have. I would post a link except they took the listing down, unfortunately. Visually, they look pretty similar to these based on the constomer pictures but I haven't tried those exact ones, so I can't say for sure. But, honestly, most round velour pads I have tried between 100 and 105mm work and sound great. (I have totes full of pads, lol) The more breathable the velour frabric, the better, in my experience (so more suede-like materials aren't the best choice). Also, being too shallow can mess with the midrange, so you want a similar thickness to Hifiman velour ones, or thicker.
I have also tried the VelPad. Has better imaging than a regular round velour donut, given that it's angled, but while it sounds similar, it has some more spice to the treble which I can find a tad harsh at times. Also, not quite as comfortable to me as the velour pads I use currently, so I always end up going back to those.
Anyway, wasn't intending to prattle on that long (so, sorry for the wall of text!), but it's par for the course when I start talking about stuff like this... Lol
![he62 (1).jpg he62 (1).jpg](https://cdn.head-fi.org/a/12220546.jpg)
Finally with my favorite headband...
Shane D
I dove in deep with Dekoni pads. I bought two sets (one for Grado's and one for Focal Clear's). Landed was about $350.00Cdn. and I don't use either set.Yeah, stuff gets pricey in Canada Land! I can totally understand not wanting to drop that kind of dough. I haven't tried the Ether pads specifically since I don't feel any pad is worth the ~$100 USD it would cost me, stateside. I got burned a long time ago buying pricey pads that everyone swore were awesome and I hated the sound of them. So, I typically won't drop over $50 on a pad without a really good reason. I have tried several genuine lambskin pads on the 6se and all had some similar traits (that I don't care for) so I really haven't pursued the Ether ones.
The HiFiman velour ones are only $10.00, but they are not angled and I don't think they come with mounting rings. So, toss in a set of rings and you are looking at $20.00, plus shipping which will at least double the price. If I pick up a set of Really cheap headphones in the near future (Closed back Sundara's at $149.00?), I will toss those on the order.
theangelboy
FWIW, If you buy the genuine round velours from Hifiman, they should come with rings (at least the set I bought did).The HiFiman velour ones are only $10.00, but they are not angled and I don't think they come with mounting rings.![]()
Shane D
Even better!FWIW, If you buy the genuine round velours from Hifiman, they should come with rings (at least the set I bought did).
leeperry
Galvanically isolated his brain
- Apr 23, 2004
big struggle or matter of fitting it in please?
kernel8888
- Jul 11, 2013
I’m telling you guys- dekoni egg shaped velour are where it’s at
This is the procedure for changing the headband if anyone is interested...big struggle or matter of fitting it in please?
