bagwell359
Yeah, I am most likely going to pull the trigger on the HE6se. I am currently coming from a HE500 and while I have listened to the Susvara pretty extensively, I think that I would still be happy with something like the HE1000v2 because I still have no problem with my HE500. Amplification will not be a problem as I have a SUSY Dynahi coming in. When it comes between the HE6se and the 1000v2, the biggest determining factor will be whichever one has less sibilance and more subbass rumble and presence.
I've had to abandon the 6SE for now. I bought a parametric EQ to see if I could fix the issues at 1.5 kHx, 3.8 kHz, 6-7ish kHz, 13 kHz. If I only need to nail the 3.8 kHz issue to enjoy them, then I'll make an inline filter, and mothball the EQ (got it cheap).
I've gone back to my modded HE-500 and HEX v2 for relief. If I can't change the issues then it'll go down to the HD-600 level with 5% of my listening. And the the other two will split the 90% - with the 500 getting a bit more than the HEX v2. The HE-500 is a great can, battling for top spot back in 2011 (Inner Fidelity), and it battles with the HD-600 as the best used can under $425. If you have both, there isn't much you can play that isn't very well served.
