gimmeheadroom
Because it looks like a used catheter
and they need high temp tubing for that (vein) purpose?
seriously, what is the official name for this material and where I can find some?
Hybrid velour..............and as noted they are stiffer than the Vegans but still expect them to relax a bit. Really like the sheepskin but wanted a soft surface against my face. Not too stiff for my liking...........There is a sheepskin and a velour - which ones are you enjoying?
It sounds awful -IMO.I do wonder how hard it would be to just get some para cord and pull one end off of the Hifiman cable and sleeve it with the para cord.... its not that the cable sounds bad its that it feels like cat gut in your hands...
Ragnarok does a good job of showing up, but the CFA3 really shows off at both ends.and what findings do you have? Pardon if you've already done this.
On first hearing, I like this low priced cable on amazon.com better than the stock cable for my HE6SE:
FAAEAL Replacement Cable for Hifiman SUNDARA Ananda,Upgrade Cable for Hifiman HE4XX/HE-400i/HE560/HE-350/HE1000 Headphones 2.5mm/3.5mm/4.4mm to Dual 3.5mm Jack Male Cord 1.45meters/4.7ft (4.4mm Jack)
Sorry, which vegan pads are you referring to? I have the Dekoni Velour for hifiman, but don't love how stiff they are. I'm actually a vegan, so lambskin is no bueno for me, but these ones aren't my endgame.Hybrid velour..............and as noted they are stiffer than the Vegans but still expect them to relax a bit. Really like the sheepskin but wanted a soft surface against my face. Not too stiff for my liking...........
Love me some Arctic grills and the GUCraftsman 6N single crystal copper cable at amazon.On first hearing, I like this low priced cable on amazon.com better than the stock cable for my HE6SE: FAAEL Sundara cable - amazon- under $20.
