The ADX5000 is a lot more mid forward and has much better resolution, is very fast for a DD can and even has better soundstage compared to the HE6SE. Jazz, classical., vocals, acoustic sound great out of the ADX5000. But I prefer the HE6Se for rock, pop, blues and even EDM which somehow don't sound very convincing on the ADX5000.I see that you have ADX5000, how does it compare to HE6se ?
Hifiman HE6-SE
- Thread starter ufospls2
Like wise, I’m almost to middle earth and still diggingDo I ever...
True story. (See Slim’s inventory)Like wise, I’m almost to middle earth and still digging
thefitz
- May 22, 2015
While I probably haven't tried your headphone amp, my speaker amp made my HE6se sound better, and all my other balanced headphones!The truth is that I’m perfectly happy with HE6se but you know about this rabbit hole…
Maybe I should try speaker amp (my headphone amp is class A 2x10w @50 ohm however).
cfranchi
- Jan 9, 2016
Just some practical questions:
Do you use hifiman adapter? Your dac is directly feeding the speaker amp ? Do you need a pre amp ?
Thank you
thefitz
- May 22, 2015
I do not use the Hifiman adapter. I bought a 4-pin XLR to banana plugs adapter on eBay, plus I even made one myself that worked great (but looked ugly).Just some practical questions:
Thank you
DAC is plugged into my preamp, which then feeds the speaker amp.
As a cheap-ass proof of concept, I once plugged my DAC into a Schiit Sys passive preamp, which was then plugged into a $50 speaker amp I got off eBay. Worked great.
Now, it's my Gumby -> Freya -> Speaker amp (Bryston 3B ST)
tkddans
- Jul 18, 2016
I can second this arrangement. Except I use Schiit Sys to make my tube amp pump out a more approriate volume than the tube amp would do normally. My tube amp is actually powerful enough for most scenarios of playback except classical, or high dynamic range music, or music mastered a bit lower than most.As a cheap-ass proof of concept, I once plugged my DAC into a Schiit Sys passive preamp, which was then plugged into a $50 speaker amp I got off eBay. Worked great.
My chain is:
Schiit Bifrost DAC —> Schiit Sys —> Xduoo TA-30 (see signature for tubes used).
The HE6SE works great with plenty of headroom on the THX solid state amp (offered on Drop), but I’ve found the TA-30 tube amp to do well with the HE6SE, albeit with needing the Sys boost sometimes. I find the tubes gives slightly more energy somehow to things in a way I like, compared to solid state.
cfranchi
- Jan 9, 2016
So a preamp is mandatory ?I do not use the Hifiman adapter. I bought a 4-pin XLR to banana plugs adapter on eBay, plus I even made one myself that worked great (but looked ugly).
thefitz
- May 22, 2015
... I’ve found the TA-30 tube amp to do well with the HE6SE, albeit with needing the Sys boost sometimes. I find the tubes gives slightly more energy somehow to things in a way I like, compared to solid state.
Huh? The Sys is passive. "Cranked" volume is the same as running a cable between the two devices. It's cut-only.
thefitz
- May 22, 2015
Yep. I mean, otherwise, you're supplying the headphones the full amount of volume without any way to attenuate. Unless you do so digitally, but even then that can fail.So a preamp is mandatory ?
Many headphone amps also double as preamps. I was using a Schiit Mjolnir 1, then Topping A90 to feed the power amp at one point.
tkddans
- Jul 18, 2016
Say that to my much louder headphones!Huh? The Sys is passive. "Cranked" volume is the same as running a cable between the two devices. It's cut-only.
EDIT:: Now I probably need to try comparing the two again just to be sure I’m not going crazy. But I’m pretty sure the volume knob on my tube amp only needs to go halfway or a bit over to get to similar volume of full rotation (with Sys in the chain).
thefitz
- May 22, 2015
The Sys is not powered and therefore cannot add volume. The knob cranked full is zero db. Cut only.Say that to my much louder headphones!
The Sys adding volume is impossible.
But then again, we have $1800 headphone cables so ¯\_(ツ)_/¯
tkddans
- Jul 18, 2016
I’ll be home soon to try it out. I feel a bit silly now after misunderstanding what the product was doing haha.The Sys is not powered and therefore cannot add volume. The knob cranked full is zero db. Cut only.
Now I’m a dingus with an unnecessary addition in my chain! Damn though. I really thought it was louder…probably just a severe lack of comparing and the fact that the TA-30 is loud in any case.
thefitz
- May 22, 2015
Well, there's absolutely a use case if, say, the volume at 9:00 is far too loud - it's a second, "in between" volume control that gives you more usable control.I’ll be home soon to try it out. I feel a bit silly now after misunderstanding what the product was doing haha.
In my experimenting, I had a Bryston preamp and I could barely get the volume past... off before I'd go deaf. It would be great for that kind of thing.
cfranchi
- Jan 9, 2016
Ok I understood, I didn’t figure that speaker amp don’t have volume control.
Total: 6 (members: 0, guests: 6)
