Vegeta55555
WARNING: BAD TRADER!
Aka: SUB40 and numerous other accounts.
- Jul 24, 2010
my amp is rated at 125W/8Ohm (the 30-40 wpc was just a guess from me)
I have never thought about using the headphone out until you mentioned it.
Certainly the headphone out takes more volume pot setting (7 o'clock vs 11 o'clock position). And the speaker out has clearer sound. The headphone out sound softer and a little bit fuzzy, but I was quite surprise that the headphone out works a lot more better than I thought.
The more time I spend HE-6 with this Rotel, the better I like the SQ of this combo. With a just a little bit tone down on treble (to remove some tiny edges and the effect was very subtle), the tonality sound quite "right" to me now. The vocal texture is getting quite close to my T1+Phoenix combo. The T1 projects a smaller but more 3D-like soundstage, something like miniaturized sonic theme. The HE-6 projects a much larger scene and hence every sound source is larger than what T1 puts out. Again, it is like sitting at the front row in a movie theater. The focusing may gets a little bit used to and difficult due to the sheer size of the scene. For vocal, HE-6 makes the singer just right in front of you and T1 puts some distance in between.
It is quite different and interesting to compare the strength of both phones. Now I hardly can say which one is better. It is just completely different flavor.
And I just went through several large-scale music such as POTC soundtrack vol. 4. The soundstage was immense and the waves of sonic power dumping at me rounds after rounds were amazing and quite a experience.
I think the Apex P/V pairs nicely with the HE-6. The Apex P/V, IMO is a pretty transparent amplifier, so in this case you will hear the tube choice and the cans more than anything else. So it depends on what you are looking for in terms of sound, but I don't feel that this combo is lacking in power, although some will say on paper it does. I really just don't get the feeling it is. But sure you could just go straight for the WA-5![]()
Although I do not believe in worthwhile audible differences between well designed amplifiers , and certainly don't buy into the "HE-6 needs at least ...... Watts to reach it's full potential" story. (The main reason I don't usually post much here, sorry I'd rather trust the numbers than my ears) my post was not intended to beat dead animals of any species.
I was simply a bit alarmed by several stories (your's being one of them) of people hooking them up to the headphone outputs of integrated amplifiers, and cranking up the volume to 11:00 o-clock, which with many if not most amplfiers could very well be max power if used with a high voltage source.
Maybe you are using a source with much lower output voltage, in which case everything is fine, but if you are using a CD player/DAC/Soundcard that puts out 2 volt, 11:00 o-clock for normal listening is probably dangerously close to the amp clipping, potentially harming your headphones. (I have more experience with loudspeakers, I don't know if headphones are just as sensitive to a clipping amp as a tweeter is, but it's still something to keep in mind)
I also think the use of speaker outputs is a very risky affair, particularly on vintage amplifiers, since there can be several reasons why an otherwise perfectly silent amplifier can cause loud distorted noise, probably destroying the HE-6 immediately. I once had an almost new Denon amp cause a very loud bang over my loudspeakers because a lightbulb from a lamp connected to the same wall socket blew (It never did this again afterwards). Age, DC offset, and several other common malfunctions can also cause an older amplifier to develop loud "switch on/off" bangs almost over night, and the buzz of a loose/shorted interconnect could probably also blow your HE-6 with such extreme wattages .
So, just a word of warning to all you amp-tweakers, no harm (and certainly no repetetive discussion) intended.![]()
