ksorota
If you are looking for bass extension into the low frequencies then you will do very well with the HE6, pair them with a Vidar and a Saga+ and you have a setup that to me is hard to beat. The Bass is not punchy like a dynamic driver, but gives you the presence factor of rumble around you. The older HE6s tend to need some mods, I have not heard the V2 HE6SE, but it is said to be the easiest to listen to stock. I did have the V1 SE and thought it sounded very good stock, better than my Auteurs.
The HE6 is a heavier headphone overall, but I never had too much issue with the weight. You should probably also look into the HE500, which has more bass emphasis and impact than the newer Hifimans.
I ended up selling my HE6 4screw after reviving an LFF Code LEX (HE5LE Code X). It is slightly easier to drive and get all the performance out of, and also sounds very close to the HE6, but with more treble energy, which I like. I also owned the V1 HE560, and believe me or not, it was damn close to the HE6 in tonality and performance...maybe 85% there.
