I95North
- Jan 19, 2012
Well said I'm not getting rid of my set even though its not working now and i'm waiting on drivers to test. HE-400 is beastly to me also even though i realized from the beggining they seemed colored to me but in a good way!
Hey again i'm not an audiophile though!
I compaired HE 400 to a friends AKG K701 and i was like HAh? My HE400 is mildly recessed in the midrange. Great lows with fantastic Hi end. It clobbered my buddies K701 In every aspect except for a wider sound stage and yes thats all nothing else. Guess what my buddy is buying next>> HE400 over the plastic muffled sounding K701.
My buddy said... "Wow i never knew my akg's sound so plastic like, dull and lifeless" His words not mine....
Oh well a Fiio E11 was used to test both headsets out.. Black Sabbath "War Pigs Live".. mp3 format
For those "sitting on the fence" I would like to add, that I think it is quite difficult sometimes to get a proper idea about the scope of a certain issue with (the sound of) a headphone - in this case the "small soundstage" of the HE-400 and how "dark sounding" is it really?
You won't know until you hear it for yourself of course, but a comparison to a headphone you have or have heard may help. I have earlier compared the 400 to the HE-6, but many potential HE-400 buyers probably haven't, so I will add a few comments compared to my Ortofon eQ-7 and EarSonics SM3 (even though these of course are IEMs and closed). These are roughly in the same price category and are considered being in the very top of the universal fit IEMs sound quality wise - look here for instance:
http://www.head-fi.org/t/476315/top-tier-universal-iem-comparison-chart-frequency-response-charts-discussion
In short: the HE-400 just hammers them completely!
Both the eQ-7 and SM3 are IMO significantly flawed compared to the HE-400 - and this is specifically in terms of frequency response. If you think the HE-400 is dark sounding then the SM3 is going to sound pitch black to you. The eQ-7 has a sound signature reminding me of the AKG K701: bright sounding with a lean bass, however a tight one. Neither IEM is satisfying to me. I am going to sell them, because the HE-400 sounds som much better than these and can be driven by my HM-801 (and I seldomly listen in noisy environments). I was on the lookout for a custom IEM, but now I might "just" get the RE262 - again.
In terms of sound stage, if that is important to you, then you are most likely not searching for the HE-400 anyway, because then you are probably listening to classical and other genres, where this part of the reprodution is more important. If you however are mostly listening to pop, dance, rock, hip-hop and other genres, where a good bass should be present and instruments usually are recorded with the microphone quite close to them, then the HE-400 will be a very, very satisfying headphone. I actually prefer the HE-400 for pop/dance over the HE-6 - that's how good it is!
If you listen to classical etc. once in a while also, then the HE-400 will do this also in a quite okay manner, but won't excel in it however, because the soundstage isn't as big as for instance the AKG K701. I sold the K701 when I ordered the HE-400 and I am very satisfied with the swap. In terms of refinement, purity, transparency, resolution, timbre, even frequency response and balance etc. etc. it is very competent. Yes, it has more bass than neutral, but not much. We are talking about 3-6 dBs. It also has slightly more lower mids (maybe 2 dBs), but not anything to worry about. If you want to know what to worry for in that respect, then try the SM3! The HE-400 has a little spike at about 8kHz and 12kHz, but never sounds sibilant. Do I think the HE-400 has a V-shape (or even better: smile-shape) frequency response? Well - hmmm. Yes, I guess so, but not much.
Could I live with just the HE-400 and the HM-801 and not having the big setup with the HE-6, Master-6 and Ref 7.1? Yes, I actually think so. It's that good. (The big setup of course is better in terms of transparency, resolution, soundstage, frequency balance etc., but at a much, much higher price tag and also weighing in at about 25 kilos ...
