MuppetFace
A Special Snowflake
- Aug 2, 2010
Could you link me to where I could order 3.5mm termination cabling compatible with these cans? Thanks!
You may want to ask Fang, or you could try an aftermarket company like ALO or Moon Audio or Apuresound. I imagine the connectors are the same as the other HiFiMan headphones, so they should have them on hand to be able to make one.
But I'd try Fang first, since the aftermarket stuff will likely be more costly.
I'll probably try a number of adapters first, but if it's too bulky as I suspect then I may just order a short 1/8" cable myself to use with DAPs and whatnot.
