- Oct 22, 2011
I believe Prepro dude uses a 25Watts into 8ohms First Watt amp, not 1000W monoblocks.
Thanks a lot, gentlemen. I took a look at the measurements on innerfidelity for the Hifiman range. Based on what I see there the difference between both should indeed be especially pronounced in the treble, around 4-5 kHz and then around 10-10.6 kHz. Going strictly by the data it seems to me that the 500 is a more civilised version of the 6, not a class lower than the flagship but rather a logical evolution, even when leaving the more realistic power requirements out of the equation. But the numbers and response charts for both sure look nice, even compared to top of the line competitors such as the HD-800 (apples and oranges, i know..). I'll load up on piano (the high notes), small cymbals and dynamic violin heavy pieces when I go and audition them in october.
Talked to the shop, they have everything in stock, all of their auditioning gear has been burned in for at least 250 hours. Their tech (audio engineer) urged me to also give the EF-6 amp a try with the HE-6, claims it's a match made in heaven. Of course it's also a +- 2K USD amp without DAC vs the Violectric 181 with DAC module at 1400.
Cost isn't the primary issue for me though of course I'm not about to throw some cash away either. But I've decided to upgrade and in stead of going the incremental way just to aim for the top (that is, the top upto 5000 or so) and be done with it. Good thing I'm not into full sized speakers. Source-wise I'm set. I'll let you know how the chips fell in october 'cause at the end of the day the proof of the pudding is in the listening and personal appreciation.
I'm not suggesting one needs to purchase a multi-hundred dollar cable. I got a "nice" cable off ebay for about $50. It has neither of the problems that the stock cable has. I didn't want a new cable for sound reasons. The stock cable sounded just fine. But, to me, fixing the other issues was worth the money.
If the stock cable doesn't bother you, then you get to save a little bit of money in not replacing it. Nice. If anybody in this camp wants to buy a used spare, I've got one available.
BTW, if anyone want my EQ settings for HE-400, PM me. Removing bass on the HE-400 brings transparency out so much that it feels like the unEQed HE-400 sounds veiled.
HE-400's bass is the best you're going to get south of the LCD! I'll never EQ it down.
There's a difference between being bloated and having too much bass. HE-400's bass is not bloated, just elevated. You can't EQ the HE-400 bass down and say you've made it tighter. Being bloated is a result of lack of damping and/or too much thd.
I havn't heard the HE-6 but I can imagine it to sound heavenly when rightfully paired with an amp.
They should have a flat bass with no hump. The upper mids are comparatively shelved though you are right.
