ThanatosVI
Anandas are so much worse than the Edition X.Yes I got anandas. Don’t know it their any good as I listen to my 800s. Would like to sell anandas just don’t need them
That's terrifying to hear
That's news to me when I have my Arya's and HEXv2 side by side.My HEX is ancient at this point. If something should ever happen I'd be quite sad to replace it with something inferior. I'm also quite disturbed to learn that the Arya has worse soundstage. That's a nonstarter for me. Soundstage is more important than that last 10% of detail for me, easily.
@bagwell359
I had found an Inner Ear Fidelity frequency response chart for the original Edition X that I used as a guide, but I really didn't put much effort into equalizing. I like that you have diligently explored options. I will try your equalization with my HEX2 tonight using either EasyQ, a plugin for JRiver, or the built in parametric equalizer that comes installed with JRiver. I am always curious enough to try some tweaks. If I do find time either tonight or soon I'll let you know how it goes with your settings. Thanks for sharing.
Bro, it sounds like you just got a driver failure. Does your unit still under warranty? I think contact hifiman customer services, I believe they will help you. I am not sure if they still do service for Edition X v2 or not because it is discontinued product line. I have tried Arya, I think you could ask them if they accept money and upgrade to Arya, it is worth upgrading. You lose the soundstage, but the details, clarity and bass is better than Edition X v2. I still love my edition X so much and hope it will live for more years to come.
You can ask customer service from Hifiman, the headband of edition x v2 is not in stock but they will offer you to make a new headband straight from their factory for 100usd and the new headband will not have the edition X printed on the yoke.Is there anywhere to buy a replacement headband? The left sliding piece does not lock into the holes anymore.
Thanks for the info!You can ask customer service from Hifiman, the headband of edition x v2 is not in stock but they will offer you to make a new headband straight from their factory for 100usd and the new headband will not have the edition X printed on the yoke.
