sennfan83261
Yeah, earlier I almost added that the timbre of the HEXv2 is the closest to that of the HD650 from the planars I've tried (LCD-2.1, LCD-4, HE-6, HE-500, and the Ananda).HEXV2 is very easy and pleasant listen. It's almost like a planar version of Sennhiser HD650 with it's own difference being a planar with large cups (so imaging differences). Both are forgiving headphones. So, they can keep you listening for a long time, particularly the HEXV2.
To me, the upper-mid emphasis of the Elex provides a metallic sheen to instruments, most notably pianos, which makes its timbre, as a whole, sound a bit off to my ears. Furthermore, there's this annoying glare that sometimes intrudes symphonic works, most notably Mozart's 41st (4th movement) (Mozart 225 Box Set) (none of my other cans exhibited this issue). At work, when my Elex package arrived, I let my co-worker compare the HEXv2 and the Elex, and she (a non-audiophile) prefers the HEXv2 to the Elex based on her initial impressions. Then again, I believe that the Elex sounds a bit better with my home setup.
I have other issues with the upper-mids and treble of the Elex that I will discuss in my review of them. I see that the Elex gets bandied about as a HD650 upgrade. In some sense, e.g. detail retrieval, of course. However, in terms of timbre and overall musical enjoyment, I consider them as a sidegrade at best.
(sorry for the Elex tangent)
