Marlowe
Interesting about the FiiO K9 and the Arya Stealth, though I see you have the now discontinued AKM version. I am looking for a new amp and DAC to use in my preferred late night listening spot without moving gear or using a dongle and am currently dithering between the K9 Pro ESS version ($850 USD) and the FiiO Q7 ($750 USD; FiiO bills this unit as portable, but it's size, weight, and performance makes it more a small desktop unit with a battery power option that is transportable). Both units are based on the $1800 M17 DAP with all the player parts stripped out (the Q7 looks very similar with the same chassis and dimensions but a tiny screen instead of the M17's large screen and slightly revised controls reflecting the loss of the Android touchscreen). The major differences is that the K9 retains the M17's dual ESS ES9038PRO DAC chips and the same THX amp modules but power output drops from 3W to 2.1W. The Q7 retains the 3W power output on DC power (making the power drop in the much larger K9 appear odd) but only has one ES9038PRO DAC chip, though it has a newer and more advanced XMOS chip than the one in the K9 and M17. Most reviews found all three units to have fairly similar performance with only small differences. ATM, I'm leaning to the Q7 primarily because of its 50% higher power output and (subjectively) I finder it a cooler looking device. (I'd probably add FiiO's PL50 external linear power supply to replace its switching power brick and match the K9's internal LPS; this would make the total package slightly more expensive than the K9.)I love them on my FiiO K9 Pro, I think it really have a great synergy with this headphone.
