Ripper2860
I am on the cusp of pulling the trigger.No, but I'd say do it if you can and report back !
![Grinning face :grinning: 😀](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png)
Following up from an earlier post where I was asking if anyone knew where to find a replacement head strap. I ended up writing hifimans customer support. They let me me know that they don’t sell the strap separately and I would have to buy the entire structure.
While I appreciate the reply I’m not keen on that solution. To me it seems a bit ridiculous to not have replacement straps available, as they could get damaged or dirty. I spent $80 bucks for new pads which just arrived, and I was also not so keen on the value there as well. Not stoked on hifiman at the moment.
You have the most recent revision if it has stealth magnets. I think the headband with holes was a DIY addition. Looks like the HE1000 SE headband. I actually find the stock Arya headband more comfortable as it has some padding.What is the latest version of the Arya? Mine doesn't have the leather headband with the holes like above. My Arya has stealth magnets and nice looking headband.
But they do sell the headbands for cheapers model ...
This one The Newly Enhanced Comfort Headband (hifiman.com) looks almost identical to the Arya's, it's just different in the yoke size so they don't fit the Arya. The point is they can totally produce the replacement band, they just don't for some reasons we don't know.
Im by no means an expert in audio just a normal consumer, maybe just some context:I recently got the Arya and love it so much that I begin to check if I am driving it to its fullest potential. I pair it with the FIIO M15, balanced, high gain, over ear mode of course. I found that the volume for me is already adequate, that I never have to max out the volume. But pretty much everywhere I checked people said you need a powerful amp to drive the Arya properly. I just don't know what additional musical quality I can extract from using powerful amps. Therefore, in your experience, is the M15 already enough for the Arya? I am looking hard at the Singxer SA-1 which people said it's good for the Arya but I have no idea what more it brings compared to the M15 besides louder volume. My Arya is the v2 version. Thanks in advance for your help and insights. I tried to search for any previous posts but I couldn't find any. I do apologize if that topic had been discussed before.
Good Choice........soloist 3xp will power even the Susvaras......singxer sa1 has very little gain in high gain mode so you need to pair it with high Vrms dac otherwise it will struggle to power even the arya.....Im by no means an expert in audio just a normal consumer, maybe just some context:
Was driving the Arya with a Hugo 2 for the last 5 months, albeit satisfied with the sound sig I bought a Burson Audio Soloist x3p as an addition (power amp mode) to the hugo 2 last month.
I guess its not about "Can it drive the Aryas" but more towards "How well can it drive the Aryas". To say the least it really did bring a whole ball game to the overall musical experience (i.e. way better dynamics, layering, imaging; microdetails and mids) but the best consideration for the burson was how it tamed the treble and made it much much more smoother <--> enjoyable
I was initially bound on the Singxer SA-1 but after some deliberation sough from some reviewers on youtube quoting that burson was the better choice (also within my allowable budget) hence the decision.
But nonetheless this is just my experience, dont take it at face value![]()
Thank you so much for the information! I'll take a deep look at the Burson amp as well. So I take it that a powerful amp will bring out a different dimension of the headphone qualities instead of just simply capable of being louder.Im by no means an expert in audio just a normal consumer, maybe just some context:
