actorlife
Estimated ship date is June 29-30
Compact Player With 2-Way Bluetooth
A portable digital music player with impressive specs, the Hidizs AP60 Pro has gotten a lot of attention from the audiophile community. This new iteration improves upon the AP60 with an upgraded Sabre ESS9118C DAC chip and a maximum sampling rate of 44.1–384 kHz / 32 bit. The unit has a better overall feel, too, with rounded corners that make it more comfortable to hold. Equipped with two-way Bluetooth, the AP60 Pro can be controlled by your smartphone or broadcast to Bluetooth-enabled devices. And when plugged into your computer, it can also function as a USB DAC/amp. Finally, this player shouldn’t have a problem getting you through the day, with a 1,000mAh battery that’s rated to last 10 to 12 hours on a single charge.
Specs
All orders will be shipped by Massdrop.
Estimated ship date is May 7, 2018 PT. Update June 29-30th
After the drop ends, payment will be collected and the group’s order will be submitted to the vendor up front, making all sales final. Check the discussion page for updates on your order.
Specs
- Hidizs
- Body color: Black
- One-piece CNC aluminum-alloy body
- 2 in (5.08 cm) TFT HD screen, 320 x 240
- Bluetooth 4.0 and aptX lossless
- CPU: X1000
- DAC chip: ES9118C
- Amp chip: ES9118C
- Gain settings: Low gain, high gain
- Sampling rate: 44.1–192 kHz / 24 bit
- Supported formats: FLAC, APE, WMA, WAV, ALAC, AAC, OGG, MP3, AIFF, DSF, DIFF
- Output: ⅛ in (3.5 mm) headphone jack
- Output power: 35 mW at 32 ohms
- Output impedance: 0.1 ohm
- Frequency response: 20 Hz–40 kHz (-0.5 dB)
- THD+N: 0.005%
- SNR: >118 dB
- Dynamic range: >105 dB
- Channel separation: 113 dB
- Extended storage up to 256 G
- Power supply: Micro USB 2.0
- Battery: 1,000 mAh lithium-polymer battery
- Battery life: Approx. 10–12 hours
- System support: Mac OS X 10.7, Windows, Windows 7/8/10
- Dimensions: 3 x 1.7 x 0.6 in (75 x 42 x 14 mm)
- USB cable
