What are you looking for in the sound that isn't impressing you? Bass, mids, treble, resolution, soundstage? In my experience most of that is a factor of the IEMs, not the dap, but the dap does influence the sound of course, especially with a transparent and bright-neutral IEM like the U18t (I use mine with the U12t). I enjoy the extra punch and low end weight of the R6 Pro compared to the M11 for example. And I haven't yet seen a higher end dap that has full Andoid for UAPP (my player of choice) and streaming services. If it's pure SQ you're after, I'm sure you can get better than the R6 Pro, but you'll be spending at least double to get it, and will have to let go of some usability features in the process.I'm not comparing it to the se out
I use the balanced out simply because of the cable I got. But I guess I expected it to sound on par with the dx220 or the wm1a, I enjoy its vast eq manipulation you can do it, I like it's form factor
But as far as sound... It doesn't sound all that impressive, maybe I expected too much.
I wonder if I should return and get the wm1a... But I do like the look and feel of the device, the good Android jt has and everything else,
Using the u18t with it and am not that impressed
