IEMmasterRace
Can hiby r3p connect to an external amp while in bluetooth mode?
Really need an answer to this
Might help if you explain what you're trying to do, Bluetooth transmitter or receiver mode?Can hiby r3p connect to an external amp while in bluetooth mode?
You can stream music from R3 to an AMP with BT receiver going to your headphones. OR, you can stream music to your R3 and then going through a coaxial or a USB cable to an AMP and then headphones. Kind of like R3 > stream over BT > Qudelix 5K. Or Phone > stream over BT > R3 > usb cable > Chord Mojo. Hope it helps.
So the btr5 is the best thing to buy if i use more bluetooth connection? is the m11 sound worser than btr5? how about btr5 vs r3p??I had the M11 (BTR5 much better IMO), not a fan of sound quality. I have a set of planner magnetic Audeze Mobius which I can try wired off the 3.5mm. I had a set of Sen HD660S at 150Ohm and even my S10 smartphone could drive them.
Are you intending to use 3.5mm on balanced? Are you wanting for just your own music ort for Streaming service too?
Yes if you mostly us BT and especially if AptxHD or LDAC and even better if using balanced ear/headphones.So the btr5 is the best thing to buy if i use more bluetooth connection? is the m11 sound worser than btr5? how about btr5 vs r3p??
Even the regular R3 could do LDAC over bluetooth. Really curious about these 2 tho, sound quality wisehello,
the R3p can do LDAC over bluetooth right?
I want to replace my btr5 with r3p,
does it offer a better sound vs btr5 ?
thank you,
e.g. https://www.ebay.com/i/293686881565On Qobuz, is the number of albums in My Favorites limited to 50, and 50 for artists as well? I see 23 tracks.
More than 100 in playlists.
Is there a case with a clip or a way to add one ?
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
