bigshot
Which drum samples? Can you point to one that has a transient peak that rises at a 44,000th of a second?
I'm not talking about theory. I'm talking about the real world. There is absolutely nothing in music that even approaches a transient that doesn't span dozens and dozens of samples if not hundreds. It's important to have a general idea of what numbers represent. Use horse sense- just ballpark it and conceive of the time in your head- divide a second into 44,100 parts. Now find something in music that is faster than the fastest shutter speed on a camera. Not with acoustic instruments for sure. Even electronic instruments is unlikely. Now find something an order of magnitude faster that and you'd be talking about a one sample transient. Good luck!
Don't really dispute any of the above. However, I'm really just interested in whether the familiar arguments about 16/44.1 are actually 100% true. It's always asserted with such finality that I could not help but wonder if there was some small exception. And, since the argument (for me anyway) actually is about digital representations and not reproduction (which, at that point, just forget it... I can't afford speakers that are flat to 40Khz anyway), it's pertinent to consider impulses. Side note: A lot of electronic drum samples, actually, include what amounts to a single sample impulse.
Right, all fair points, but, I am not really worried about real-world behavior. I'm wondering whether 44.1/16 is literally beyond the limits of human hearing, even in theory, or not. I'm well aware neither 99.9% of music, nor 99.9% of gear, can max out 16/44.1, but it's fun to speculate about the edge cases.
So what you're asking/saying is that it is possible for a synthesized signal to exceed the ability of 16/44.1 to record and reproduce it accurately?At home I have a fair number of synthetic drum samples that just use a click with a rise time of one sample as their "snap". It's kind of common among old crappy samples from old crappy digital drum machines. I will see if I can find some good examples and post them here. It's not hard for them to be this way since they were artificially created in the first place.
of course you can find situations where people can notice a difference.Not really. My concern is more like, if 16/44.1 is settled on as "more than enough" as a format for storing recordings, (forget any question about reproduction), then my opinion is that it ought to be able to store just a bit more audible information than humans could ever possibly perceive. This way, it's really "future proofed" against some imaginary sci-fi perfect transducer, or whatever. Like, if it's meant to be a perfect storage medium for audio recordings, is it *actually perfect* or just close?
My point is just that there seems to be certain edge case signals that humans can hear, that can't be represented in a 16/44.1 format. So, it's not a "perfect" format as such.
Again, I fully acknowledge the uselessness of this question in real life scenarios.
...but....if you're going to forget about reproduction then it doesn't matter how it's recorded at all. You must consider reproduction or the recording process just makes no sense at all.Not really. My concern is more like, if 16/44.1 is settled on as "more than enough" as a format for storing recordings, (forget any question about reproduction),
The big problems in sound reproduction have entirely to do with the transducers and the acoustic environment. It's not a matter of a transducer not being able to produce ultrasonic signals, there are some that can. It's getting those signals to your ears that is the problem. They become highly directional unless diaphragms become very tiny, at which point they also become inefficient. With today's tweeters that go above 20kHz, their dispersion patterns look like narrow flashlight beams that rapidly narrow as frequency goes up. Aiming is critical, and listener head position is critical. As to headphones, the acoustic environment above 20kHz is radically different for each listener because of their ear shape, so getting response that is in any way consistent is problematic at best. Even with IEMs, the wavelengths involved are strongly affected by the shape of the cochlea, which isn't the same for everyone. It becomes clear when looking at the ear design that it wasn't intended to work well, if at all, above 20kHz.then my opinion is that it ought to be able to store just a bit more audible information than humans could ever possibly perceive. This way, it's really "future proofed" against some imaginary sci-fi perfect transducer, or whatever.
Nothing made by man is perfect. Nothing. It's just close enough to be acceptable and useful. It's a powerful shame the initial CD marketing used such superlatives as "perfect" and "forever", but those of us inside the industry who experienced that marketing the first time around blew it all off as marketing anyway, knowing full well none of it was actually true.Like, if it's meant to be a perfect storage medium for audio recordings, is it *actually perfect* or just close?
Those edge cases are few, specific, and non-musical.My point is just that there seems to be certain edge case signals that humans can hear, that can't be represented in a 16/44.1 format. So, it's not a "perfect" format as such.
For example, if you actually wanted to repeat this two-click threshold test done in the 70s (I found the link) http://asa.scitation.org/doi/abs/10.1121/1.1912374 you would not be able to do so with digital equipment running at 44.1Khz. The shortest click you can represent at that sampling rate is... 22 us.
If there is some audible difference between clicks lasting 20 and 10 microseconds, then we must conclude that people CAN hear (under specific circumstances) more than 44.1 can reproduce. I won't argue that this really matters for music, but if we want a standard that theoretically exhausts human ability, we may want to consider that 16/44.1 isn't it.
Yes, of course you can have drum samples of this sort*, but the drum sample is just "data" that could be turned into ASCII-text, control signal of a robot or a picture file. Or sound in this case. When you playback that sample, the DAC of your system uses reconstruction filter to create analog signal from the sample. The analog signal has limited bandwidth and depending on the phase response of your DAC has more or less pre-ringing + decay ringing. "Digital snaps" never reach your ear and it's not intended to happen. Sample snaps are digital information, not real sounds. Real analog sounds are created from that information and always band limited.At home I have a fair number of synthetic drum samples that just use a click with a rise time of one sample as their "snap". It's kind of common among old crappy samples from old crappy digital drum machines. I will see if I can find some good examples and post them here. It's not hard for them to be this way since they were artificially created in the first place.
