Jimmy-Jack
- Nov 10, 2010
[size=10pt][size=10pt] [/size][/size]
[size=10pt][size=10pt][size=10pt]Hello all, [/size] [/size][/size]
[size=10pt][size=10pt][size=10pt]I'm new here and have come seeking advice in establishing a shortlist for a headphones/amp combo.[/size][/size][/size]
[size=10pt][size=10pt][size=10pt]I want build a stand-alone headphone system. The source will be a music server consisting of a large RAID, controlled by a Mac computer; D to A conversion is via a Wavelength Cosecant USB DAC (a single ended source). I play mainly redbook files; occasionally higher res. Musical preferences: 80% jazz and classical (orchestral); 20% other. [/size][/size][/size]
[size=10pt][size=10pt][size=10pt]Auditioning equipment will likely require that I travel; before doing that, I'd like to get my bearings. [/size][/size][/size]
[size=10pt][size=10pt][size=10pt]In the non-headphone world, I use and very much appreciated SET power amps driving horns, so naturally and possibly stupidly, I've been concentrating my research on tubed headphone amps (been trying to get my mind around the offerings from both Woo and Eddie Current), but am open to considering others. [/size][/size][/size]
[size=10pt][size=10pt][size=10pt]As for headphones; I'm totally open.
Budget: Open.[/size][/size][/size]
[size=10pt][size=10pt][size=10pt]I spent the day reading this forum and in it, have discovered a wonderful resource; at the same time, I must admint to being overwhelmed by the quantity of information... I'll keep reading. Meanwhile, I send out this request for advice.[/size][/size][/size]
[size=10pt][size=10pt][size=10pt]Thanks in advance.[/size][/size][/size]
