Dec 22, 2015 at 12:18 PM Post #16 of 20
  I got a pretty decent fix for the headphones regarding the tab issue in particular. My tab broke completely on my left ear, and was worn on my right ear, so I decided to replace both completely.
http://imgur.com/a/UC0GQ
I used: Pliers, drill/adequate drill bits, screwdriver, two small screws, two square washers, and two nuts.
I removed the covering bit completely, as it was purely cosmetic. I used the pliers to clear some of the plastic in the way so I could drill into the plastic. The rest of it was pretty simple. Works like a charm now!
I'm trying to use this technique... how did you remove the covering?
thanks
Dec 22, 2015 at 1:30 PM Post #17 of 20
I figured it out :).  tore some plastic off with pliers then popped it off with a flat head.  No hardware store here in South Carolina had a square nut, so I ended up using a speed nut.
thanks !
May 16, 2016 at 6:36 PM Post #19 of 20
My both hinges also broke after 4 years of service. So I decided to fix them. The only thing you need is a set of small screwdrivers and one (or two) paperclip(s).
Short guide:
Step 1: unscrew the screws as shown is the picture below
Step 2: Take a paperclip and fold it as show in the picture below
Step 3: Hook the paperclip behind a screw
Step 4: Screw everything back together
Step 5: Fold or cut the remaining parts of the paperclip
http://s32.postimg.org/7geh1nwk5/fix.png
Nov 15, 2016 at 8:37 PM Post #20 of 20
Short guide:
Thank you for that, i went and did something similar seems to be working.  I made a double loop in a small paper clip and screw it back up with that triangle holding the cup.  Cheaper than getting the Atticus..
