I currently have a FIIO K3 and recently bought a set of HD650's, I figured it's time to get a new amp. I wanted some recommendations for which ones to get, I figured you guys would help. My budget is around 200$ give or take. I would also like to know if I can use my K3 as a DAC out for my new amp, if so then the budget would be 200$ for just an amp, otherwise it would be 200 for a DAC and amp. I was thinking the Little Dot MK2 would be a good one, or the Schiit stack/Vali. Any reccomendation would help, thanks!
Help with an amp and or DAC recommendation
- Thread starter Josh650
- Tags
- amp dac hd 650 reccomendations
PurpleAngel
I would say you want to spend as much as you can for a headphone amplifier and to just keep using the K3 as the DAC.
The 300-Ohm HD650 improves with the more voltage it gets.
Maybe get the Schiit Asgard.
