quoam
- Jun 13, 2012
Hi all,
My HE-500 cable sounds great but is not ideal. It picks up every single sound of rubbing/tapping against clothing, tables, gear, etc. Its will-to-tangle is ungodly -- even after I suspend it from above and connect it as 'flatly' as possible, moving between instruments/PC has it arching and coiling in no time. My cats find it fascinating, and these fascinating things tend to die.
So I'm looking of ways to fix these problems. I'd like to retain its flexibility but be a little sturdier, thicker maybe, to stop it tangling so much. I'd also like to make it matte/dark -- when the kinkiness and silvery shine go, the cats shouldn't be so intrigued. The microphonics (?) can hopefully be stopped or at least lessened by whatever I use.
I'd appreciate any ideas you have on the subject. Can't afford to spend much cash but surely I can do better than wrapping it in cloth tape...?
Thanks.
Thanks.
