Jan 22, 2012 at 7:04 PM Thread Starter Post #1 of 7
Derpster
I'm looking for a pair of <$150 in-ear headphones, ones that have great sound quality. Bass, enhanced but not over-powering. Mids great and balanced. Highs crisp and clear. Please Help! :)
Jan 22, 2012 at 7:10 PM Post #2 of 7
What genre of music you like listening to?
If it's electronic then I made EXACTLY the same thread....
I'd recommend either Yamaha EPH-100 or the Atrio MG7.
The latter is more bassy without bleeding
Oh, might be a tiny bit overbudget
Jan 22, 2012 at 7:14 PM Post #3 of 7
By the way Beatbox, and Derpster, welcome to Head-Fi. One thing is Beatbox, its best when you recommend things to state that you haven't actually heard the earphone you suggest, otherwise second-hand recommendations can be a bit confusing for new users.
But yeah, I think it may be helpful for Derpster to have a look at your thread :D
http://www.head-fi.org/t/591705/150-iem-to-listen-to-electronic-dance-music-fxt90s-vs-eph-100s
Jan 22, 2012 at 7:19 PM Post #4 of 7
The Sony EX600, UE TF10Pro, JVC FXT90, Yamaha EPH100 and Etymotic HF5(bass light compared to others but very detailed in mids and extended highs with tight isolation) are recommended.
