Help! Need help (directions) how to change the jumpers on my Little Dot MkIII?
Oct 15, 2010 at 7:32 PM Post #2 of 4
David has an explanation right here in the PDF under "little dot MK III gain control " and there little switches that can be accessed from the bottom of the unit that correspond with these settings mentioned in the PDF.
http://dl.dropbox.com/u/6037680/Little%20Dot%20MK%20III%20Reference%20Guide.pdf
BTW I ordered a little dot MK III ( now if I am lucky I will receive it by tomorrow
Oct 15, 2010 at 9:57 PM Post #4 of 4
Can you post a picture of the bottom of the amp? At any rate if this is not resolved by today I will likely have my amp by then and will have to figure out how to change the gain as well and if I do I will post back and let you know as well. Alternatively you could ask David from little dot as well he has amazing customer support!
