Bombo
- Feb 4, 2007
Hi there!
My audio background very, very deprived: SB-Live + $150ish computer speakers. I am a clean slate. And I'm really keen to jump into the audiophile realm. Budget is $200-300AUD to start; but can be expanded to $500AUD without causing too much extra pain. However I'm reluctant to do this because I'm really just getting my feet wet, and the law of diminishing returns should ensure that I get something that sounds pretty damn amazing to my untrained ears for just a few hundred dollars. I'm basically looking to get the absolute most bang for my buck with this entry system and build from there.
Headphones:
After lurking for a while it seems that the smartest place to start would be grado. I live in Australia so the prices are a little higher/odd: I absolutely cannot decide between these three Grado's as a pair of starter cans: Grado SR-60 ($125 AUD), SR-80 ($150 AUD) or an Allesandro MS-1 ($150 AUD). They all seem to get rave reviews, and each have different qualities which are not necessarily better or worse. I don't know how the MS-1 would cope without an amp, and also the whole ear-pad debacle is confusing. I'm open to other brands of course, but Grado's seem the be the most recommended place to start.
Amp:
I travel a bit so portable is ideal for me. Is it worth holding off for say a hornet outright, and running them directly out of my computer / iPod; or should I buy something like a PA2V2 or as an interim amp? Is the Hornet or a similarly priced amp sooooo much better that it's worth just buying one right now as part of my introductory system?
Source:
Will be mainly a computer, some iPod. Is the Chaintech AV-700 soundcard ($40AUD) a given? Perhaps some DAC+AMP combo like the Headroom Total Bithead would be a good start also. If I get an amp I'll need an iPod Line-out cable too. Are the ALO cables worth the huge price you pay for them, or are there better alternatives?
Thanks very much guys. This seems like a great board and I can't wait to contribute!
![smily_headphones1.gif](http://www.head-fi.org/forums/images/smilies/smily_headphones1.gif)
Headphones:
Amp:
Source:
