plaidplatypus
- Jan 9, 2006
The RS-1 is a very good choice. Larry has a pair, I'll ask him what amps he likes with them.
Originally Posted by plaidplatypus /img/forum/go_quote.gif The OP is buying a Ultra Micro DAC, see post #15. Pete's last name is Millett not Millet here's his website: Pete Millett's DIY Audio pages I've heard the TTVJ portable Millett Hybrid twice, both times I went away impressed. It sounds better than many full size tube amps. Here it is at Todds website: TTVJ Millett Hybrid Amp - $459.00 : TTVJ, Todd The Vinyl Junkie |
Originally Posted by plaidplatypus /img/forum/go_quote.gif I've owned two Headroom amps and they both were fine products. One of them had the previous version of the Max module that is in the Ultra Micro amp. Grados were my favorite headphones with that amp. I would take the WA6 over this amp unless space was a major issue. I've heard a B22, it was like my HeadAmp Gilmore Reference but with more power. Larry will have to fill you in on how the RS-1 sounds with the HeadAmp because I've never tried that combo. I would get HeadAmp GS-X rather than a B22 because I've been seriously impressed with the consistent quality of Justin W. amps. My tube speaker amp only takes a few seconds to warm up. The down side to tube amps are that you can't stack things on top of them and eventually you might have to replace some tubes, think of them like long-life light bulbs. This is a long-shot guess but the Luxman P-1 may be worth looking into if you simply will not have anything to do with tubes: Luxman P-1 [P-1] - $2,400.00 : TTVJ, Todd The Vinyl Junkie http://www.head-fi.org/forums/f36/lu...rogram-370453/ |
Originally Posted by Sherwood /img/forum/go_quote.gif The amp you want at your budget is a Beta 22. It is a phenomenal, absolute top of the line Headphone and speaker amp. It can built moderately, or extremely maxed, depending on your budget and preferences. Go ahead and go balanced -- it's worth it for when you eventually try Sennheiser HD650s. It is DIY, so will need to either buy one used on this forum, or find someone to build you one. Good options abound for builders here, though I'm not sure who's currently making them. Expect around $1200 for this, and don't expect to find anything better for less. |
