mfaughn
- Jan 28, 2009
Hi all,
I have come into possession of some DT48S headphones. One of the drivers isn't production sound. I suspect that there is an open circuit between the little brass screws that hold the cable terminals in place and the leads from the voice coil. It really old and gummy in there. I've poked around in there with the leads from another cable to see if I could get it going but no joy. The connection assembly isn't looking so hot. The little screws had white stuff all over them when I extracted them. I'm suspecting it is residue from the plastic that the assembly is made of. Am I right that there is no way to get that assembly out? It seems to be glued in. As it stands, all I can figure to do is hack it apart with and exacto knife and hope to heck that I can find the voice coil leads in there and solder directly to them (probably using paste -- its a tight space and delicate wires and paste will minimize the heat and other possible screw ups for me). Anyone have any thoughts?
I have taken the driver apart but I didn't test continuity for the coil on the inside. Probably should've but my MM was downstairs and I"m lazy. FWIW, I wouldn't advise anyone to take the driver apart unless they have to. Naked voice coils scare me. Way too fragile.
-Michael
-Michael
