emin007
- Oct 15, 2010
Hello guys,
just ordered some Denon D2000's after much debate and auditioning at local stores! I now need a amp to run these guys to their limit. I'm looking for something without DAC's and RCA inputs. Looking to keep the whole thing under $300 total street price. If you have any suggestions please reply with links if you can. Thank you in advance!!!
ps currently considering:
Audiophile Products Cute Beyond : HERE ARE ITS SPECS: ALL UNDER $200 INCLUDING SHIPPING
BUT NOT INCLUDING THE UPGRADED POWER SUPPLY (POWER SUPPLIER)
Text
[size=9pt]Headphone[/size] | [size=9pt]Impedance (ohms)[/size] | [size=9pt]Cute Output (mW)[/size] | [size=9pt]Sound Level (dB)[/size] |
[size=9pt]AKG 240DF[/size] | [size=9pt]600[/size] | [size=9pt]60[/size] | [size=9pt]106[/size] |
[size=9pt]Sennheiser HD600[/size] | [size=9pt]300[/size] | [size=9pt]120[/size] | [size=9pt]118[/size] |
[size=9pt]AKG 501/401[/size] | [size=9pt]120[/size] | [size=9pt]300[/size] | [size=9pt]119[/size] |
[size=9pt]AKG K270S[/size] | [size=9pt]75[/size] | [size=9pt]480[/size] | [size=9pt]119[/size] |
[size=9pt]Grado SR60/80[/size] | [size=9pt]32[/size] | [size=9pt]320[/size] | [size=9pt]121[/size] |
[size=14pt]Specifications:[/size] | |
[size=x-small][size=10pt]Circuit Design:[/size][/size] | [size=x-small][size=x-small][size=9pt]Single Ended, Class A[/size], uses no coupling capacitors[/size][/size] |
[size=x-small][size=10pt]Main Op-Amp[/size][/size] | [size=x-small][size=10pt]Burr Brown OPA2604 - Interchangeable[/size][/size] |
[size=x-small][size=10pt]Output Resistance:[/size][/size] | [size=x-small][size=10pt]Extra low output resistance (Zo < 0.05 ohms),high current capacity[/size][/size] |
[size=x-small][size=10pt]Frequency Response:[/size][/size] | [size=x-small][size=10pt]6Hz~300Khz ,-1dB at 100 ohms loading, very low noise[/size][/size] |
[size=x-small][size=10pt]Max. output:[/size][/size] | [size=x-small][size=10pt]6Vrms (with 24 VDC Power Supply)[/size][/size] |
[size=x-small][size=10pt]Headphone Impedance:[/size][/size] | [size=x-small][size=10pt]26 - 600 Ohms (See headphone matching chart for additional information)[/size][/size] |
[size=x-small]Stereo Crosstalk [/size] | [size=x-small]-90.0 dB[/size] |
[size=x-small]Dynamic Range [/size] | [size=x-small]104.6 dB [/size][size=x-small](1 KHz A-wieghted) [/size] |
[size=x-small]Total Harmonic Distortion [/size] | [size=x-small]0.0018%[/size] |
[size=x-small]Noise Level:[/size] | [size=x-small] -104.7 dB (1 KHz A-wieghted) [/size] |
[size=x-small][size=10pt]Size: [/size][/size] | [size=x-small][size=10pt]Size: 11cm / 4.3in(L) x 8cm / 3.2in(W) x 5cm / 2.0in(H)[/size][/size] |
[size=x-small][size=10pt]Shipping Weight: [/size][/size] | [size=x-small][size=10pt]720g / 25.4oz[/size][/size] |
