Stephonovich
- Jan 6, 2003
Yet another computer thread... /me cackles maniacally
You do realize you're going to get about 50 different opinions, each one different?
Ah well. Here's my take.
Mobo: MSI K7N2 Delta Platinum - $90
Mobos are very much a personal choice, providing you pick a decent brant and chipset, that is. I myself am very much a MSI fan, having dealt with their products and customer support. This particular board comes loaded to the gills, and won't kill you in price, either. Support up to 3GB of DDR400 dual channel RAM, 1x AGP 8x, 5x PCI, onboard USB 2.0 and Firewire, 2x PATA, 2x SATA, onboard RAID 0/1/0+1, onboard 6-channel audio, onboard Gigabit LAN. Granted, you won't be using the onboard audio, but it's practically impossible to buy a mobo today that doesn't have it. As for onboard LAN, I know people are going to bash me over this, but I really don't have much of a problem with it. MSI's usually pretty good at including a decent chip for their LAN, and since you aren't going to be doing any major file transfers, it'll work fine. Consider Gigabit icing on the cake. As for onboard USB 2.0 and Firewire, I've got the former, and it works very quickly indeed. Haven't dealt with onboard Firewire, but it usually works well enough for most people's purposes. If you plan on doing heavy video editing, buy yourself a card. Another bonus, this mobo comes with round IDE cables as well as SATA.
CPU: Athlon XP-M 2500+ - $88
'Nuff said.
CPU Cooler: Speexe WhisperRock II - $8.99
So long as you aren't overclocking (indeed, it seems you want to underclock...), this will do nicely. Actually has quite good reviews, and is very, very quiet.
Hard Drive: Seagate 80GB SATA 7200RPM - $69
Seagates are quiet and reliable, plus they've got a 5 year warranty. As for capacity, I don't care what you're doing, there's really no good reason for you to go lower than 80GB. You never know what you'll be doing 2 years from now, and besides, dropping down to 60 or 40 isn't going to save you much at all. As for SATA, it's cheap enough on this drive that you might as well. You're not going to get a performance boost, but believe me, working with SATA cables is a whole lot easier than PATA, even rounded ones.
Optical Drive: NEC ND-3500A CDRW/DVDRW - $70.99
With DVD burners being as cheap as they are, there's really no reason not to get one. This NEC was rated by several computing sites as the best burner available, period, and is also one of the cheapest. It's can burn dual layer discs, and is quite zippy at 16x.
Floppy Drive: NEC 1.44MB Floppy - $7
Hey, say what you want, floppies aren't dead
Video Card: ATI Radeon 9550 128MB - $68
Basic previous-gen card, but does have a 128-bit memory interface. If you ever get into gaming, this will at least let you whet your taste for future upgrades. Also, it has DVI-out if you got a monitor supporting that.
Sound Card: You're on your own, man. If this is an audio computer, seriously, it's all up to you. I saw you mention an Emu back awhile... excellent. Just get whatever you want, pop it in.
Case: Antec Quiet Black Midtower 350W - $60
Never, ever, EVER skimp on cases or power supplies. I learned this the hard way. Granted, I've now got an übercool ghetto modded system with more holes and vinyl ducting than steel, but you don't want to do that
Antec cases are great, they're easy to work with, and their power supplies are very stable. It's also got front USB 2.0 ports, something that's always nice. Also, note the fan count... 1x 120mm exhaust. That's right, just one. Do they work? Oh yes. 120mm fans pull an insane amount of air, and are extremely quiet. Now, if you were to put a hotter CPU and graphics card in here, you'd want to add another 120mm in the front for intake. But for what you're doing, this will be awesome, and quiet to boot.
Total price... OK, so the price comes out to around $500 with shipping. You did say 'About $400', right?
Anyway, this is base. Just pick and choose from everyone's posts here, make sure the parts are compatible, and go from there.
Oh yes, for monitor/keyboard/mouse, I'm assuming you already have one. If not, Viewsonic makes really nice monitors if you can swing the price, if not, I've heard BenQ isn't bad. For keyboard/mouse, Logitech.
'Nuff said.
