Hey lucozade, So now you got me really interested in the Westone 3, how do they differ from the UM3X. I noticed that they have a mic option for the iPhone but I can't find them for under $300 I really want to spend under $200 but will spend the extra money if I have to. I've heard on this forum that some websites will hook up head-fi members (the site may have been earphonesolutions.com not sure?). The 3's have three seperate BA drivers and I read that they don't interact with an amp as well as Dynamic drivers do. So for DEEP thumping bass (I want it to sound like the Beats by Dre Studio or a sub in my head) the 3's are my best bet without an amp? (or are the UM3X?)
I read a lot of reviews on the IE8 and it seems like they have thumping bass out of the box but various reviewers referred to them as having a "burn-out" feature as opposed to the supposed burn-in. I really want thumping bass and am wondering what would give me the the deepest and lowest frequency bass when using an amp (I'm under the assumption now that the Westone 3's or Hippo VB will have the best bass without an amp). Will it be the IE8's or the bigger driver VB's or the Shure SE530 or even the TBP gold. Both the Shure and Monster's should be capable of overcoming thier mid-bass hump with an amp and EQing I would hope.
Any suggestions on a good preferably affordable amp? One that would fit very well with my iPhone 3G-S? Do portable amps have EQ setting to play around with
I don't know of any portable amps that have eq settings but several amps like the ibassio p3+ which i use have rollable opamps and buffers,which are little circut boards which provide the amplication, there are ones for bass, midrange ,treble ,soundstage etc.The p3+ has 4 channel arcitecture so you can use various combinations of opamps to get a sound your happy with.By the way its not true that ba drivers dont work well with amps, i use my amp all the time with all my iems
The se530 bass does not go down to the lower frequencys,it has plenty of mid and upper bass though if you fit it your ears correctly.
The ie8 has the widest bass frequency ,although it is not the best quality bass or the most detailed and like i said its mid bass hump does colour the vocals,but this can be removed with eq or the right combination of opamps in a portable amp,it just depends how much you value accruate vocals in your music
and the ie8 are the warmest iem i have,and yes the bass does lessen with burn in.To me the ie8s bass sounds like a double bass while most other iems sound like electric bass guitar
Ive not heard the umx3 but from what ive read it has the best locational ques of eny iem but a small intimate soundstage and a bit boring detached sound.
Have you considered the ie7, this has the same type of bass as the ie8 but without the over emphized mid bass and colouring of the vocals ,the treble is not as good as on the ie8 but its not bad either and the midrange is more forward then the ie8 ,also the soundstage is a little smaller but its still one of the biggest of eny iem
