Problem solved but there's another one....If I connect the SB-Z to my 2.1 by using RCA cables the sound is terrible! I nearly can't understand the words of a song the reason could be the bad quality of the cable? Or maybe some dust in the 2.1 RCA in?
Before I was using optic fiber and for the SB-Z I bought RCA, I tried to change cable: problem fixed! That's strange because a cheaper cable works better. :S however do I have to disable "HD audio" on the bios?
Yes. You should disable the motherboard audio chipset in your bios. Generally, even a budget RCA cable will work fine, unless you bought THE cheapest cable you could find on the Internet. Then maybe you have an RCA problem. So best to troubleshoot some potential configuration issues first.
