Chris J
Can't remember if I've posted this link in this thread.
Too lazy to go thru old posts.
Some info about the whole power, voltage, current, impedance thing:
http://www.head-fi.org/a/headphone-impedance
I like the water analogy, Liamstrain, thanks! And thanks for the link Chris, looks extremely helpful.
So I messed around with the gain switches again, and though I may be entirely wrong, to my ears there is a huge difference in sound quality between running the M-Stage at 10dB with the K702, and running it at 0dB.
At 10dB, the volume knob indeed sits at a comfortable 4 - 5, which as we say, "looks right." It's also great because it gives it more room to go if I plug two headphone sets in, or on a quieter passage of music or whatever.
But...
When I switch back to 0dB, the knob may have to move to about 6.5 - 7 to get the same volume, but what results is a much broader, and more detailed soundstage in the K702. I am going to double-check tonight yet again, but this is already the second time I've noticed the difference. And it is a big difference. Plus, with trance, I noticed the music was fatter and more present at 0dB as well. 10dB and above thinned the sound out and placed it farther distant, with the effect intensifying with each raise of the dB of gain.
After double checking again, if I prove right on this then the question becomes why the rise in gain has this effect.
What does feedback actually do, anyway? Why is it there?
I stick with 0db and then move it to 10db if I'm attaching 2 sets of headphones to listen with a friend, as it requires more umph to power both headphones with enough volume to hear adequately.
Nevermind, I found out that the headphone outs on the A1 are pure tube driven instead of hybrid like the line out, so it probably wouldn't play too well with the AKGs.
