RickG
Electrostatic Elvis
- Aug 2, 2001
Hi Vert. The following is a direct quote from the HeadRoom site:
"You’re probably wondering what the “top ten” headphones used in our reference headphone composite were. As chosen by the HeadRoom staff for the purposes of our measurements, they were: the Sennheiser Orpheus, HD600, HD580, and HD495; the Beyer DT250-80 and the DT831's AKG K1000 and K501; the Grado RS1; the Sony CD3000; and the Stax Omega. You may notice that the list actually contains 11 headphones. That’s because we decided to measure 11 so that we could throw one out. We knew that we might run into a headphone that measured oddly even though it sounded amazing. Such a phenomenon is a very common topic of discussion in high-end audio; at times you find a product that is pleasing to listen to, but has far from ideal technical performance. In the list above we found that the Stax Omega was the odd man out. This headphone is a world class performer in terms of the positive experience reported by listeners, but when we measured it we found an unusual artifact in the bass: a very large upward spike and then a rapid drop. Though these headphones are frequently criticized for not having enough bass, we certainly don’t perceive them to sound like the curve looks. We decided not to use the Stax Omega data in the standard on grounds of it being out of the ordinary, even though they certainly belong on the list of best-of-the-best headphones."
Originally posted by Vertigo-1 I hope that's just a list and not the order they consider the headphones to fall into from best to worst, because yeaaaah...uh huh...I'll bet the HD-495s and the DT-250-80s are better than the CD3000... ![]() |
![smily_headphones1.gif](http://www.head-fi.org/forums/images/smilies/smily_headphones1.gif)
