exsomnis
- Nov 12, 2012
They still do make binaural recordings. Dr.Chesky has done some albums recorded binaurally but I find that they only serve to make it seem like the sound field is slightly larger than your head. They also don't convey life-size like voices and instruments. Novel but not convincing.
The other thing about headphones are the positional cues. Move your head up and down and the soundstage is strapped to your head, moving with it. So if you turned 180 degrees or were in a handstand upside down, the soundstage would follow you. Instead of how it would really sound in real life, where the band is in a fixed position and turning 180 degrees means that the band is playing behind you.
VR does address this, but there is yet to be a headphone only application that is focused on high fidelity.
