Originally Posted by HFat /img/forum/go_quote.gif
You can read all sorts of nonsense online... and offline too for that matter.
Agreed, and I guess the only way to really decide for myself is to listen to each pair on my own, but unfortunetly time is a little tight right now. That, and I can't find any stores in the Trenton/Princeton/Edison, NJ (Basically anywhere up Rt1) area that has many of these models.
All the headphones that have been recommened for your dad aren't closed... it seems that reading people's requirements is too much work for the posters intent on pushing their favourite cans. |
Indeed, but I'll take all advice and viewpoints. I am pretty set on closed headphones for my dad, but not 100% sure sure about ones for myself. There isn't as much of a time constraint on myself so I might hold off on buying a pair for myself till I have time to go to B&H later in the month once the semester is over.
Of the phones you listed, the HD280 and K271S are closed. The consensus is that the K271S sounds better and is more comfortable. Maybe the 240A is closed too but I don't recognize that model. |
I've been fortunate to actually listen to the K270 which is basically the same model as the K271S and I was impressed. If my schedule doesn't allow for an NYC visit by next weekend, I might just bite the bullet, buy the K271's, and return if necessary.
Originally Posted by facelvega /img/forum/go_quote.gif
HFat, I don't see the grounds for your sneering, considering that by my quick glance at least four of us explained that open headphones would likely suit the OP's father's home listening better. Of course someone just learning the ropes would at first think that closed are more practical, and I think it's helpful to point out that this might not be the case if there is no serious ambient noise to block and nobody within a few feet to be bothered by leakage. The fact that the OP listed five open headphones in his seven original options seemed to indicate that this was still an open question for him.
I do appreciate your honesty and advice. I am a novice about headphones and high end audio equipment, but I am interested in learning, and I do want to make sure that I get the right product for my dad. The reason that I think closed would be best is that our house is always noisy. Between the kitchen, my sister always having friends over, and me when I am home from school, it isn't so much a matter of sound leaking out, as it is the rest of the household making noise that will leak in.
In terms of what to get for myself, I think I can look at some open air designs, but ones that don't leak as bad as the Grado's. That'll require a trip to B&H or J&R to test for myself.
