Update! This new amp is nearly ready to go. Just need to finalize the circuit board (what's in the pictures is a prototype, and there are changes), and have the enclosures machined. The enclosures are machined from 3 blocks of USA aluminum, creating a unique set which will then be sanded/polished as 1 block, creating a seamless appearance. They will then be laser engraved in-house with great detail.
Specs? All subject to change, as this represents the prototype.
Enclosure - Milled from solid USA aluminum, dimensions about 4 x 2.25 x 0.8"
Design Type - Single Channel Op-Amp with Discrete Output Buffering (hand-matched components)
Power Supply - 2x 9V batteries of any kind, removable battery door on bottom
Reverse Battery Protection - Yes
Power Indicator - 1.8mm Red LED
Max Output Voltage - 14-18V (subject to change)
Max Output Current ~200mA/Ch (subject to change)
3-Way Gain Switch - 1x, 5x, 9x (subject to change)
Volume Control - Alps 9mm rotary, hand selected
Battery Life (subject to change)
Non-Rechargeable Batteries
Lithium Primary - 100 hrs
9V Alkaline - 50 hrs
Lithium-Ion 33 to 41 hrs
High Capacity NIMH - 25 hrs
Med Capacity NIMH - 21 hrs
Low Capacity NIMH - 17 hrs
