Headamp Blue Hawaii Special Edition
post-15247182
Post #9,436 of 9,452
bmichels
France, Belgium and Morocco
Hi bmichels
Nice rig there. I spotted an 813? Is it an RCA 1943?
I have those in my amp. Also some nice Mullard 813 made by Philips in France about same vintage.
Mullard CV26
post-15247197
Post #9,437 of 9,452
astrostar59
Member of the Trade: Aries Cerat Espana
Somewhere v hot
Somewhere v hot
Mullard CV26
Interesting. Mullard CV26 is a copy of the 813 which RCA invented. Most Mullards are actually made in France by RTC or Philips I am told. I have a set of 4 Mullards branded in my stash, with made in france on the back.
The Mullards have a more hexagonal shield, the RCA rounded. Mullards tend to sound better, but not in all cases....
post-15262874
Post #9,438 of 9,452
bmichels
URGENT Question: My tube supplier needs to match my EL34 Quad. He wonders what plate voltage and what Bias voltage he should use to match them for a BHSE ?
Also can someone tell me what plate curent (mA) should be expected for a perfect NOS ? is the higher mA the better ?
thanks in advance for your advices
Reactions: tumpux
post-15263037
Post #9,439 of 9,452
JimL11
Albuquerque, NM
Albuquerque, NM
The BHSE has +/1400 volt supplies. According to Kevin Gilmore, EL34 tubes run at 18mA plate current - this is set by the current loads, and the original BH cathode was at '350 volts, so a cathode to plate voltage of 350V should be close. For matching, he could run the EL34 triode connected with 350V cathode to plate voltage, adjust the plate current to 18 mA and match grid voltages.
post-15264365
Post #9,440 of 9,452
bmichels
thanks a lot for those valuable informations.
post-15358532
Post #9,441 of 9,452
rickles
MA
MA
Is there a general consensus about which headphone sounds best with the BHSE? I am debating on getting a set of SR009S, or 007mk1(70xxx) to add to the BHSE I'll be receiving next week.
Reactions: BreadMaster
post-15358780
Post #9,442 of 9,452
ALSO
Each will have a preference I'm sure, but BHSE is the first amplifier that truly opened up the 007 mk 1 for me--until then I never understood the fuss, but now they are my favorite. But they don't quite work for the 009, in my opinion, which I pair with a Mjölnir-Audio KGSSHV mini Carbon.
post-15358843
Post #9,443 of 9,452
rickles
MA
MA
Makes sense, thank you! I see people talking about modded 007mk2.5 with the BHSE. I also read about the 009s. Are either of these the bees knees with the BHSE over the 007mk1?
post-15358869
Post #9,444 of 9,452
ALSO
I have one set of 007A but haven't modded it, and frankly was never crazy about the earlier versions of them. I think the 007, which sounds like nothing on most STAX drivers, maybe with the exception of the 14S, sounds crazy good on the BHSE, so I use that pairing. Maybe others can weigh in on the 007A pairing with BHSE.
post-15359083
Post #9,445 of 9,452
kevin gilmore
Señor Stax. Señor MAXX.
Can Jam '10 Organizer
+/- 400v power supplies
1400 volts is a whole bunch harder
Reactions: Jones Bob
post-15359086
Post #9,446 of 9,452
rickles
MA
MA
The man himself! Kevin- Do you have any thoughts around which non-unobtainium headphones sound best with the BHSE?
post-15428023
Post #9,449 of 9,452
rickles
MA
MA
I was told there was a youTube video by Justin that illustrates tube biasing for a BHSE. Can't find it. Ayone have a link to it?
Weird. I think it was taken down. My YouTube link doesn’t work.
post-15428308
Post #9,450 of 9,452
Charlottesville, VA
Charlottesville, VA
Website
www.headamp.com
I decided to make the video private so that I can discuss the instructions with anyone who needs it, make sure they have the right equipment, and make sure they understand the purpose of the adjustments and see if adjustments are truly necessary. We've had a couple of instances of amps damaged by abuse, which is not covered under warranty.
Reactions: jgazal
