astrostar59
BannedMember of the Trade: Aries Cerat Espana, Auriculares High-EndAKA Headstage, headphoneweekend
Sorry, second paragraph, I meant - who built your KGSSHV (not BHSE).
I think my next major purchase will be a DAC in the same price-range as a BHSE.
I don't own a KGSSHV, maybe you're referring to purk's latest post? Currently I'm using a Cavalli Liquid Lightning (which has some mixed reviews, but I really think it happens to sound great).
Alluding to your comments about your DAC, the weakest part of my system now really is my source. The DAC and SACD player I'm using now are both very good, around the $1K range for each, but with an SR-009 and BHSE or Liquid Lightning, I realize they're the bottlenecks of my current system. I think my next major purchase will be a DAC in the same price-range as a BHSE. I'm familiar with your DAC's brand, Audio Note, as well as David1961's brand, Esoteric. I would love to have a DAC from either of those companies, but those are just a little out of my price range currently.
Take a look at exasound (Canada). I have one of their e20 (- see avatar ) with 82fs clock upgrade and I am very happy with it. I use a Krell CD-DSP as source for redbook and the DAC made such an obvious difference compared to the built in D/A, it's not even funny.
It's about 3k $US and comes with 30 days money back if you are not happy. I have not heard it in comparison with any ultra expensive DAC's (e.g. dcs) but I think sonically this is one of the best values out there. It's pretty light and a small package but if you're concerned about the SQ as first priority, I highly recommend to check it out.
If you just need the DAC without a transport, I'd strongly recommend you read some of the reviews for the dCS Debussy. You don't 'need' a clock, but you could add an atomic clock later, and that would give you a fantastic very high end sound for under $10k.
Hi Jackskelly
You know the DAC run is a kit I built up. It costs 2,150 US for the DAC 3.1, and it sounds fabulous. If you are in the USA they can build the kit up for you for another 250 US approx.
Something to consider. I personally would put this unit up against DACs costing 5 times that price at least. A none oversampling DAC with tubes can sound extremely musical and less processed
or digital IMO.
http://www.ankaudiokits.com
... For the BHSE owners here, is the amp particularly sensitive to the source? That's probably a stupid question, haha, I imagine any amp of great quality would be sensitive to the source. ....
Not a BHSE owner ... but anyway just a little correction in logic or maybe phrasing :
The amp amplifies whatever signal comes in. Ideally without any alteration (famous wire with gain).
Consequently the all applicable saying "Crap in crap out" holds true also here.
In case of a high(est) quality amp, it will just amplify any crap and will not dress it up with some coloration to play nice.
Supposedly the BHSE is the most "non-tube" like tube amp, if that makes sense .
So I guess, if that's the right context for your question, then possibly a "yes" is the best bet.
Whilst we're waiting those last fewdaysweeks for the new batch of BHSEs, here's an update for tube rollers:
One of my second set of Psvane EL34PHs the tubes failed yesterday. The set is about 5 months old, with very roughly 400-500 hours of usage.
The failure was near identical to the failure I had with the previous set:
After about 3-4 hours of being on, one of the tubes started crackling loudly (both externally and through the headphones) coinciding with sparks of light near the top of the tube. I didn't wait to see how the fireworks display would end, so no damage done.
Whilst waiting for Rachel's response (the grant fidelity warranty is 90 days), I'm again looking for alternatives. So any more feedback from the newest contenders? Mesa Boogie STR-447, Tesla and anything else that's been tried recently? Golfnutz, have the Mesa's smoothed out over time?
Because of comments from The Attorney and David, I purchased a "matched quad" and the pin assembly on one of the four simply came undone, crumpled with insertion into a maxi-matcher tube tester
