Head-Fit: Software Crossfeed and EQ
May 18, 2010 at 7:24 PM Post #61 of 318
The new version is buggy like that with mine also. I noticed that when you double click the executable before using the dll, it fixes it. Also with any version or many of them, the sliders don't show the number/value change unless you have music playing on foobar while setting it.
May 19, 2010 at 5:47 AM Post #67 of 318
I went back to 1996 by the way from 1870. Very slightly better with my limited testing :D
Tried Vnophones again and its really no contest against headfit since the high frequencies bleed more than the lows and can't be synced.
May 21, 2010 at 1:06 AM Post #69 of 318
The maker of this plugin should work for apple and implement this plugin for the apple firmware for the 5gs and classics :D I heard this plugin has similarities to the crossfeed in rockbox but when I used rockbox, the settings were different. Also rockbox is too inefficient and not as clean as the apple interface so I don't really care for it.
May 21, 2010 at 2:09 AM Post #70 of 318
I used to use Roickbox on a H140. The crossfeed was very powerful but lacked the subtlety of Head-Fit. I eventually stopped using it because the frequency shifts were too great.
May 21, 2010 at 6:22 AM Post #71 of 318
Thats what I thought too. I thought the rockbox xfeed was too crude. Maybe headfit is a more refined version of that rockbox crossfeed circuit because the guy that makes this is supposedly the guy that worked on the one for rockbox.
Jun 22, 2010 at 8:08 PM Post #75 of 318
